ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: malodin on November 01, 2006, 08:22:54 PM
Title: New member glad to be here, pix of my tracker
Post by: malodin on November 01, 2006, 08:22:54 PM
Hi all, i love the website already have gotten a ton of information neccessary to facilitate repairs on my tracker.
Here is a few pix.
(http://img.photobucket.com/albums/v603/malodin/trackermods/0423061744.jpg)
(http://img.photobucket.com/albums/v603/malodin/trackermods/160d08dc.jpg)
(http://img.photobucket.com/albums/v603/malodin/trackermods/0511062052.jpg)
pics are without the coil spring spacer
Some stats
1993 geo tracker lsi, 3" body lift, some minor fender trimming, 31" tires, 1" coil spring spacer, 1991 toyota mr2 100amp alternator(pretty easy to install, pm if you want to know how, i might get around to doing a write up on it if demand is enough) soon to have a volvo td05-12b turbo on it.
Alex
Title: Re: New member glad to be here, pix of my tracker
Post by: 89tintop on November 01, 2006, 10:40:48 PM
welcome and please do a write-up on the alt conversion, I am sure there will be a ton of interest.
here is my rigs.
Post by: Rhinoman on November 02, 2006, 03:45:48 AM
x2
Post by: stock93tracker on November 02, 2006, 08:11:21 AM
x2
x a bajillion
Post by: TehkTracker on November 02, 2006, 10:02:43 AM
Welcome.  Your Tracker is almost identical to mine 8)  I just ordered 1" coil spacers too.
What are the benefits of the 'yota alt. install?
Post by: 89tintop on November 02, 2006, 12:06:31 PM
no drag with winches and offroad lights.
Post by: malodin on November 02, 2006, 03:13:46 PM
100 amps as compared to 55, dont neccesarrily know if its more readily available, but i would think being for a toyota its easier to find one at out of the way autoparts stores.  There is one bug i still have to work out before i do a write up, but perhaps one of you guys can help point me in the right direction.
the plug on the alternator is the exact same plug as that of the trackers plug, i.e. the terminals are in the same position for ig and l which is what made me decide to try and mount the yota's, however now that its all hooked up and running, my alternator light stays on, ive checked voltage at several different places and i get a steady 14.62 volts(at idle)(i think this is due to a different pulley diameter)....so i know my alternator is charging, ive test everythying i can think of, its definately putting out amps, i can turn on brights, a/c, radio, everything i have and not have the lights flicker a bit, but what i dont get its that the light is tied to the l terminal on the alternator, and as far as i can tell doesnt actually go through the computer so the computer is not reading a different amp or something and turning it on, it should only be turned on by the alternator.
however since i dont have a fsm for the tracker i cant trace that wire very well, i just know the alternator is charging.
Alex
