ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Chief on January 09, 2005, 10:33:07 AM
OK, gettin ready to put this sammi case I have into my tracker. I have it on the floor, and try to run through the shift pattern. I have 2wd hi, and 4wd hi, but I can't get into low?? ???
The shifter only moves back and forth, not to either side AT ALL. Do I have a problem?
Shift rods weren't lined up right or the shifter sheet is bad.
What's the fix?
What's the fix?
Pull the shifter, align the shifter forks and make a square box. Ensure that the rubber bushing under the shifter ball is in good shape. If not order a new shifter sheet (bushing) Put in the bushing, Put the shifter back in and it should work like a champ
if ur sammi has more than 50,000 miles on it replace the spring, shifter pin, and the shifter bushing that should cure ur problem or just order the kit form hawk. http://www.hawksuzukiparts.com/
I think the kit that you are talking about is for the trans! not the tranfer case.
Any pics? Also, what do you mean make a box? Make a box with the shifter forks?? Never had the top end of a t-case apart!
OK, youguys are confusing me!!
I'm having trouble with my TRANSFER case! ;)
Pull the TC Shifter, there are two shift rods that should look like this [size=10][][/size] if aligned properly in neutral. Check the rubber bushing (sheet) to see if it's worn.
and that rubber bushing is right under the shifter, correct? Thanks for the help!
If your lucky you can pull the shifter out and use a large screw driver to align the shift pins without taking apart the case.
I know someone sold a tool you could use to pop the spring plate off without having to drop the transfer case, not sure where to get it though. You could make one easily enough though.
shift rods = shift pins???
Is there some bible on sammi cases so I can do some research???? ???
So how far have you gotten? do you have the shifter out yet? is your shift sheet good? how are your [] looking when you look down the shifter hole? do you know the shift pattern?
No where!! Just got the trackick back together yesterday. Grounded the starter, put the manifold and exhaust back on, rear d-shaft, modified 4x4 tranny x-member.
Today's the intake, adjust clutch linkage, get shocks mounted in the rear, redo the coil captire for the rear springs, and then I'll do the shifter. I hope it's nothing serious!!!! :-/
Can you take some pictures of your Transfer Case where your shifter goes in?
well, got the case shifter pulled, and I can only get the hi range pin to move. Low range won't budge. I didn't get to screw with it much, but I couldn't get the two pins to align correctly.
I guess I'm gonna have to pull the case apart?
The low range shift pin was (I think) slide far forward, like towards the front of the vehicle if the case was in. I tried to move it with a screw driver, no luck. :-/
Anybody help me with this??? The case is going in this weekend, so I'll have to pull it back out and f with it.
What do I need to do???? ???
The shift pattern is going to be backwards from the shift knob to the pins or rods,there are ball bearings between the rods to keep them in order, if the case is sitting next to you like in the rig the passenger side rod should move,if you move it towards the front of the rig the rod next to you (driver side)should now move back towards the rear of the rig, if not you need to pull it appart and check things out.
Looks like I'll be pullin it apart..... :'(
http://www.spidertrax.com/drivetrain_dah.htm
This the shifter sheet I Needed for the t-case?
Looks like it to me. Here's a Sammy FSM you can download:
http://www.hardcore4x4.net/fsm/
ya the dah-001 should do it.
