ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: track_this on January 11, 2005, 07:04:13 PM
Title: calmini
Post by: track_this on January 11, 2005, 07:04:13 PM
does anybody know the extended and compressed lengths of the rear shocks on the 3" sus. lift, also does any body have the link to the article on how to over rotate your rear end? i cant seem to find it.
my front end sits leaning to the drivers side alot, i have just installed the 3 incher, any body ever hear of this or know what the prob might be?
thanks.      shane
Title: Re: calmini
Post by: Zukipilot on January 11, 2005, 10:33:03 PM
Did you make sure the tapered ends of the coils are facing the same (up). Did you  over tighten the control arm mounting bolts, binding up the suspension where it does not travel smoothly?
Title: Re: calmini
Post by: Zukipilot on January 11, 2005, 10:34:22 PM
Here is the link to the Rear rotation article, Mr Hagen wrote
;)http://www.zukiworld.com/month_100102/feature_hagans_rearrotate.htm
Title: Re: calmini
Post by: mbmarkyb on January 11, 2005, 11:30:13 PM
was it 15" to 22/23 i think
Title: Re: calmini
Post by: mudfkr on January 12, 2005, 04:45:22 AM
I had to remove the rubber dampeners on the front spring cones  and trim the inside of the rubbers down to allow the spring to slip completely over it and settle properly as mine was hanging up and sitting cock eyed too. Remember being a 1/4" out on the spring can make huge difference to how it sits.
The springs on mine were a little disappointing compared to the quality of  all the other Calmini components, they had slag around the top where they were gas cut before being wound which  made them also binded up on the spring cones. I had too grind the ends and clean them up which is not a big deal but it annoys me that the spring maker would send them out like that.
Title: Re: calmini
Post by: track_this on January 12, 2005, 06:41:18 PM
hey thanks this weekend im going to take an inspection and try to see whats wrong. the drivers side (the one that sits lower) moves really well (i jumped on the front bumper)but the pass side is a little more stiff, so maybe i over tightned ::) well thanks again, still gotta do some more tweaking before "spring" is here
shane
Title: Re: calmini
Post by: stuperzuki on January 15, 2005, 09:12:52 AM
HMMMMM,   AND JUST HOW MUCH DO YOU WIEGH??? :-X :-X :-X
