ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: ZukiPower on November 20, 2006, 07:51:00 PM
Hello all!
My transfert case work correctly but the "4WD" light don't go on.
The lightbulb is good, so I suppose the switch in the t-case is stuck by rust or something but I just don't find it! Does anyone knows where it is hidden? :-\
I check under the central console but wasn't able to locate the damn thing!
It's a minor problem but a little irritating. I suppose it will not be that difficult to correct once you know where to look. :o
Thanks.
Oups!
Just checked a couple of old posts.
If I understand, the 4WD switch is not simply linked to the shaft. The fact that it's not on can mean the 4WD mode is not engaging at all.
Ok, now I'm worried! :'(
MERDE!! >:(
I believe that that is only the case on the later models with air actuated diffs/hubs. On earlier models the lamp is simply grounded by the switch in the tcase.
Really? Wow thanks Rhino. I really hope your right.
That's a real relief, since my zuk is a '93 I suppose that it means than only the switch is faulty.
Still, I haven't find it yet! ???
