ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: clg93tracker on December 04, 2006, 12:52:15 PM
I have a 93 Tracker with a BDS 2". I was wondering if I would have any issues with adding 1" spacers to these coils. i.e. drive shaft ext. or diff. drop
thats a good question that i wished I knew the answer to have you checked the archives yet, I would but i can never find anything there.
i put 1" spring spacers ontop of my calmini 3" kit.
never had any probs with it. ;D
You will run into problems with strut length, camber angle, rear top mount ball joint, probably brake lines, prop length and a few other things too.
At the very least you should fit strut spacers, camber bolts and a rear diff spacer. Front brake lines can be relocated. Not sure about the rear I have braided lines.
Flipping your top strut mount will give your struts the 1 inche that you lost with the coil spacers
Yeah I'm considering doing that, the Calmini package is more comprehensive than others. A BDS 2" kit + 1" spacers is like a Calmini 3" without extended drop link brackets, trailing arms, v-bar and control arms.
My opinion is the Calmini 3" kit can adapt to 4" without putting additional stress on the replacement arms/brackets (recomend RRO's driveshaft extension). However the BDS 2" kit is already pushing your stock arms/brackets and drivetrain, if you add a inch spacer, at 3" Calmini decided that droping the front axle, and extending the trailing arms to the rear axle was neccesary to prevent dammage to your factory components.
i think if you won't drive to hard it would be ok ???
i'm running 2 1/4" coil spacers in the front and it is fine.
