ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: biker053 on January 09, 2005, 09:27:33 AM
Title: samurai to rotary
Post by: biker053 on January 09, 2005, 09:27:33 AM
i am fascinated by this swap and want all the information i can cram in my brain. i have found some information on por and some on zuwharrie but zip here. somebody here has did it. please any information is greatly appriciated. here are some basic Q's i have to get you started. what year and model of rotary is easiest to swap? which is all around good? and which is the best performer?what year rx do they come from? and what motor trannycombos have you seen? how did you stuff it in there? how did you get the tranny to work with the transfer case? all is good. thanks in advance.
Title: Re: samurai to rotary
Post by: 1bigtracker on January 09, 2005, 10:00:32 AM
http://www.izook.com/tech/samurai/engine/rotary/Rotary_Engine.htm
Enjoy! ;)
stu
Post by: Chief on January 09, 2005, 10:00:38 AM
well, I don't know much about the swap, but you'd prolly want one from the 2nd gen RX-7, and if you can find it, get a Turbo'd one! As far as the tranny, just use the stock units behind the engine. For a transfer case, just divorce mount any unit you want, or keep the sammi one. I think the 2nd gen are from like 86-91, I think. The post 91's are all sequential twin turbos. Prolly be a PIA to swap over and get to work right.
As far as engine and tranny mounts, I would suspect it would all have to be custom made. But the engines are tiny, so mounting them should be no problem.
Good luck with the swap, I someday want to get a 4wd bone stock tracker and swap in the 13B turbo. Things can easily be made to reliable put down 250 hp at the wheels!
Post by: biker053 on January 09, 2005, 10:57:46 AM
thanks but i have read the izook article i thought it was lacking detail that is what i want.
Post by: bandit86 on January 09, 2005, 01:36:47 PM
I hear a turboed rotary can weigh in the neighbourhood of 450 pounds, same as an all aluminum LS1 smallblock.   if thats the case, go v8
Post by: explosivo on January 09, 2005, 09:51:39 PM
lololo... you just said that you can make a rotary engine reliable! ;D
Post by: adamd on January 09, 2005, 11:19:01 PM
LOL! I'd go with a Quad 4 engine... of a 3.8 v6 outta a grand prix of something..
Post by: zookiemike on January 10, 2005, 05:19:49 AM
What are you implying? My buddy drives his Ma,zuki as a DD and has never had a probleme. It has an 88 13b. All the fuel stuff was fun and took him about 4months too complete. it's all about the oil and how often you change it. there a great idea and i would love too have a P,port 12a in my samurai ;D.
Post by: LawDog on January 10, 2005, 01:01:14 PM
The idea of the swap seems merely novel.  What are the real benefits??  I must agree with explosivo, put one of those in a Zuk and go muddin and your just asking for trouble.
Post by: mesjr2004 on January 10, 2005, 01:13:57 PM
i dont know about mud but i have seen a rotery in a rockcrawler ,jeep baised frame rx7 motor tranny with a sammy t case,49'' irocks  dana 60s,and it would fly down the trail and climb annything,saw it in disney ok.
the guy runs the campground i think,ive got picts but not shur if their on disk or not.ill check if they are ill post them.
Post by: mesjr2004 on January 10, 2005, 02:12:45 PM
(http://www.eye-irritant.com/august2004/green thing_edited.jpg)
correction,looks loke 2 1/2 tun rockwells. has a really cool exhaust note too.dont know why it wouldnt go in mud the motors will reve pretty high
Post by: mudfkr on January 10, 2005, 07:27:13 PM
I had a RX2  with a 12A twin dizzy motor years ago that I ended up having to pull out to do seals, they are frickin HEAVY motors !! We figured it looked so small it had to be light as well so we put a bar across the engine bay with a chain on the motor and manually lifted it out, Boy we're we wrong !!  :P
From my experience with them they must be well looked after - like warmed up before driving and running down after a hard run and regular servicing or else seals die real quick. The engine produce little torque down low so need to be driven high in the RPMs to get any power out of them which makes them hard on gas and I imagine they would  only suited to certain types of 4X4ing like MUD  ;D.
Parts used to be big $$$ back then but may be better now days ?
I used to like to caning it hard and throttling off at night  and watching the huge flame come out the exhaust.  ;D
One thing I remember with the engine/trans combo is that the starter motors were placed differently on the bell housing depending on models, I think 12a bell housing had the starter on the L/H side and 13b's were mount directly on top of the bell housing.
It's been 15yr's since I played with rotors thou so I could be wrong  ???
I used to love the sound of rotor motors  Bimmm Bimmmmmm Bimmmmmmm  ;D ;D ;D
Post by: Chief on January 10, 2005, 08:55:54 PM
Me too.  ;D
Post by: Kuehjo on September 07, 2006, 05:09:05 PM
There's one on Ebay right now (under aircraft, of all things)
http://cgi.ebay.com/ebaymotors/suzuki-samurai-rotary-powered-13b_W0QQitemZ180025576197QQihZ008QQcategoryZ63677QQrdZ1QQcmdZViewItem
Not an easy reserve, but there none the less!  Might be worth speaking with the seller...
Post by: kirknd4spd on September 07, 2006, 06:39:41 PM
ok, if you want a rotary, do what i'm doing with my 91 rx7. S5 (89 - 91 model) 13B turbo block, streetported. remove the turbo and all of its components, then take out the rotors. install n/a rotors (9.7:1 compression, compared to 9:1 compression for turbo model) and counterweights, new injectors, ecu, and harness. once you get the air/fuel ratio right, you will easily have around 200whp. bolt it to a turbo model 5 speed tranny, and use the stock zuki t-case. i was planning on doing this exact swap into my 89 kick, but its too much work for me. plus, my kick is my daily driver, and i just need to keep it running until i finish my rx7.
