ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: rockrat on December 22, 2006, 10:01:20 PM
Title: Gear reduction
Post by: rockrat on December 22, 2006, 10:01:20 PM
Back on the mill making parts again
(http://i10.photobucket.com/albums/a102/rockfab/RockReductionBox028.jpg)
(http://i10.photobucket.com/albums/a102/rockfab/RockReductionBox025.jpg)
(http://i10.photobucket.com/albums/a102/rockfab/RockReductionBox027.jpg)
Title: Re: Gear reduction
Post by: Rhinoman on December 23, 2006, 07:16:07 AM
Nice job  ;D. The gear lever on the Sammy case looks a long way over though, I assume thats to keep the oil level good.
Post by: rockrat on December 23, 2006, 07:16:31 PM
The lever stays in the stock location. The entire length was taken into account to keep the sami case in its stock position in the frame rails.
Post by: Rhinoman on December 24, 2006, 05:42:38 AM
OK, what am I looking at then. I thought that was the back end of a Track/Kick tcase and that this was a dual tcase conversion for a Track/Kick. Is this a dual tcase conversion for a Track/Kick motor  and trans in a Sammy or I am way off?
Post by: mrfuelish on December 24, 2006, 11:26:30 AM
You can use it for both, in a sammie you just have to widen the tunnel a little bit to get the trans to fit, Heather runs this setup in her four door kick with fj80 axels.
Post by: WorkInProgress91 on December 24, 2006, 03:22:47 PM
any more info on this?
Post by: rockrat on December 24, 2006, 03:36:12 PM
Just like mrfuelish stated. It is meant to fot in the rails of a zuk using 1.3 (lucky13) to kick trans and case mated to the zuke case. Keeping the zuk case in its stock location. I dont see any reason why it could not be modded into a kick with a little fab work. We are finishing up 3 right now for customers. Then I want to make it an exchange program. I will have 1 or 2 done on the self. So you just send me your case and and a slip yoke and you get the moded case back with adapter. estimated cost at this point is $675. for the exchange and no 8 month wait. Once we have the first 3 complet we will revisit time and material to get the an accuraute cost. Each case is milled in a fixture so they are all identical not hack and cut with a sawzawl. THe last pc. of the puzzle right now is the shifter the customer may have to tweek the zuk case shifter but I am working on a away around that so it will be a complete product when sold. Not a Oh by the way do this to make it work..
Post by: 89tintop on December 24, 2006, 03:41:52 PM
Not a Oh by the way do this to make it work.. what do you mean rocky rat? ::)
Post by: rockrat on December 24, 2006, 05:45:48 PM
Meaning I dont want a customer to do anything with the product other then have install it. My thought is if a customer has to bend pry, or alter something they just spent good money on to make it work, it is not a complete product and more thought should have gone into the end result. So it wont be released until it is 100%  ;D
Post by: 89tintop on December 24, 2006, 07:50:27 PM
and that is what seperates you from the other POS vendors out there. keep up the quality work scott. ;D
