ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: fullsink18 on January 08, 2007, 08:31:05 AM
It seems that my kick has less power now with the rear locker installed. Mainly when I am trying to climb through or on stuff.
Is this normal?
I guess it makes sense since it is now trying to move both tires. Any thoughts?
On most any rig you are turning both tires, with a locker in a turn you are pulling from the inside wheel giving you a taller gear ratio instead of splitting the diffrence with spider gears, so go streight and no diffrence ;D
I thought so. I only really notice it when i am turning.
But i can tell it is helping. There is a stomp that i tried to climb on before the locker and the kick just spun and never got on it. I got the locker and it started up the stump but then ran out of power in 4 lo. So i guess i need some crawling gears huh.
what gear are you in try airing down your tires and when all else fells gas it :P
i bought my samurai with a rear locker already installed. i try not gas it or power through turns. i was told its hard on the locker and tires. anytime i make a sharp turn i try to build momentum first and roll through it with the clutch in. otherwise i have lots of tire chirp. i have the grsII t case from petroworks. it has a high in 2 and 4X. the gearing is really low. the thing will dig holes and spin tires before it runs out of steam. works pretty good. i would reccomend it.
