ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Eden1 on January 10, 2007, 11:24:08 PM
Title: gas tank
Post by: Eden1 on January 10, 2007, 11:24:08 PM
I see alot of guys asking about lifting there tanks.What I was wondering is could you put a bigger tank in or build a bigger tank to fill the void left by the body lift?I know I think its a pain in the ass to fill up every couple days.Also I put 31x10.5x15 boots on the other day and the tracker sucks up the fuel pretty quik now.Is this normal?This is why I am thinking bigger tank you see.Anything helps. Thanks guys.
Title: Re: gas tank
Post by: Gary_Hill on January 11, 2007, 12:01:10 AM
Larger tires moved out of normal rpm range and decreased your fuel efficiency. On the up side you are going farther and faster on a gallon of gas than your odomiter and speedo says you are. Confusing ? Every modification is a trade off...
Are you going to MOAB?...Gary
Title: Re: gas tank
Post by: Rhinoman on January 11, 2007, 04:56:30 AM
No reason why you couldn't fit a bigger tank. Like Gary says your fuel consumption will be worse but the mileometer will read low so it may not be as bad as it seems.
