ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: sidekick101 on January 19, 2007, 06:40:26 PM
where is the hole on the enign to putan oil temp gauge and is there any need for a boost gauge on a stocker 1.6l 8V? if so where do you put that one
theres no need for a boost gauge unless its turbo
To fit an oil pressure gauge you normally remove the stock oil pressure switch and fit the oil pressure sensor instead. You can fit a T piece to allow both to be used. You may need an adapter, the stock switch is an M10x1 thread.
