ZUKIWORLD Model Specific Suzuki Forum => Suzuki Grand Vitara, Vitara, Chevy Tracker (Gen. 2 Platform) 1999-2005 => Topic started by: 99Trackerconv on January 19, 2007, 06:52:33 PM
It will work for Chevy Trackers 99+ but I'm not sure if it will work for Geo's or Suzuki's
I guess if you have the RPO sticker in your glovebox it should work.
http://www.s10forum.com/rpo/index.php
Here are my specs!!!
AK5 RESTRAINT SYSTEM , "SEAT, INFLATABLE, DRIVER & PASS"
AM7 SEAT RR , FOLDING
AN4 RESTRAINT PROVISIONS , CHILD
AR9 SEAT , "FRT BKT, DELUXE"
BNN COMPARTMENT , "STOWAGE, CARGO AREA"
B1A PORT OF ENTRY , CAMI
B58 COVERING , "FLOOR MAT, FRT & RR, CARPETED INSERT"
B84 MOLDING B/S , EXTERIOR
C60 HVAC SYSTEM , "AIR CONDITIONER FRT, MAN CONTROLS"
DL5 DECAL , ROADSIDE SERVICE INFORMATION
DR1 MIRROR O/S , "LH & RH, MANUAL CONTROL, COLOR"
FE9 CERTIFICATION , "EMISSION, FEDERAL"
HC1 AXLE REAR , 4.62 RATIO
J41 BRAKE SYSTEM , "PWR, FRT DISC, RR DRUM, CAST IRON"
K34 CRUISE CONTROL , "AUTOMATIC, ELECTRONIC"
L34 ENGINE , "GAS, 4 CYL, 2.0L, MFI, DOHC"
MM5 MERCHANDISED TRANS , MAN 5 SPD PROVISIONS
M59 TRANSMISSION , "MAN 5 SPD, SUZUKI, 3.65 1ST, 0.795 5TH"
NF2 EMISSION SYSTEM , "FEDERAL, TIER 1"
N33 STEERING COLUMN , TILT TYPE
N40 STEERING , "POWER,"
PG2 WHEEL , "15 X 5.5, STEEL"
P17 COVER SPARE , WHEEL
QCE TIRE ALL , P205/75R15/N BL R/PE ST TL ALS
T61 LAMP SYSTEM , DAYTIME RUNNING
T82 HEADLAMPS CONTROL , AUTOMATIC ON-OFF
UH8 CLUSTER , "INST, COOL TEMP, TRIP ODOM, TACH"
UL0 RADIO , "AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH"
UQ0 SPEAKER SYSTEM , "4, DUAL FRT DR MTD, DUAL STD RGE QTR/SHELF"
U73 ANTENNA , "FIXED, RADIO"
ZU1 PACKAGE , "PICK-UP BOX DELUXE""" <---- what?
ZY1 COLOR COMBINATION , SOLID
1SB PACKAGE , OPTION 02
17D TRIM COMBINATION , "CLOTH, MED GRAY (97) (D)"
41T TOP COLOR , BLACK (96)
89U PRIMARY COLOR , "EXTERIOR, DK MULBERRY MET (02)" <---- Thats the wrong color.. Mine is Purple Graphite Met
Whats yours?
It should work for Geo's, all three of mine have had the glovebox RPO sticker. Neither of my Suzukis has a GM RPO sticker. Doubt their influence spread that far into the Suzuki world.
Seems right.
AU0 "LOCK CONTROL, ENTRY" , REMOTE ENTRY
AU3 LOCK CONTROL , "SIDE DR, ELEC"
A31 WINDOW , "POWER OPERATED, ALL DOORS"
DG7 MIRROR O/S , "LH & RH, REMOTE CONTROL, ELECTRIC, COLOR"
NF7 EMISSION SYSTEM , "FEDERAL, NLEV"
NG5 REGISTRATION , "EMISSION, CERTIFICATION, FIFTY STATE (50)"
NV5 SHIELD , DIFFERENTIAL CARRIER
NX2 WHEEL SPARE , 15 X 6.0 ALUMINUM
NY7 SHIELD , TRANSFER CASE
N29 WHEEL , "15 X 6, ALUMINUM, SPECIAL"
QCM TIRE ALL , P215/75R15-100S WOL R/PE ST TL ALS
TZ2 EVAPORATIVE SYSTEM , ON BOARD REFUELLING VAPOR RECOVERY
U1C RADIO , "AM/FM STEREO, SEEK/SCAN, CD, CLOCK, ETR"
VM5 LABEL INFORMATION , "CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT"
ZR2 CHASSIS PACKAGE , "HIGH WIDER PERFORMANCE, 4 X 4 SPORT"
ZV1 STATEMENT OF ORIGIN , MANUFACTURE
Z05 CONVENIENCE PKG , #
1SC PACKAGE , OPTION 03
17G TRIM COMBINATION , "CLOTH, MED GRAY (97) (G)"
17I INTERIOR TRIM , MED GRAY (I) (97)
17I INTERIOR TRIM , PEWTER (99) HOLDEN
19U PRIMARY COLOR , "EXTERIOR, JET BLACK (05)"
5A0 GRILLE , "BLACK, GLOSS"
