ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: westvilleguy on January 20, 2007, 11:58:43 AM
Title: how much weight can a tracker tow?
Post by: westvilleguy on January 20, 2007, 11:58:43 AM
i found a couple trackers cheap about 2 hours from me i can drive one home mayby gotta go check them out first but the other has to be towed i think i can get a car trailer buddy uses to haul his civic to the track not sure how much it weighs or rent one from u-haul but do u think a 5 speed 8v tracker could haul this trailer with a tracker on it?
Title: Re: how much weight can a tracker tow?
Post by: TysonS on January 20, 2007, 12:20:23 PM
anything is possible but i don't think you would have much of a clutch left after that, and if there are any hills you will need to use 4low
I wouldn't do it with my own sidekick
Post by: Rhinoman on January 21, 2007, 05:41:12 AM
There have been a couple of threads about towing with Track/Kicks. It would seem that the legal towing limit for a Track/Kick in the US is considerably less than its own weight.
Post by: 97TRAKIN on January 21, 2007, 05:48:33 AM
1,500lbs
Post by: bentparts on January 21, 2007, 05:53:54 AM
1000 lbs is pushing it for a Trackick. I would'nt do it.
Post by: jzap on January 21, 2007, 05:04:42 PM
I tow a small popup camper that weighs about a little over 1000 lbs fully loaded with gear.  It tows OK, but It takes a bit to get it moving and you have to make allowances for more braking distance.
Towing a trailer with another Tracker on it would probably burn out a clutch in short order.  Somebody here posted pics a while back of a Tracker pulling another Tracker on a tow dolly (was it Zig, Digger, Zukipilot???) and said he had no problem with it.  A lot would depend on the terrain, the traffic and your skill.
Post by: kirknd4spd on January 21, 2007, 10:02:36 PM
i wouldnt do it
Post by: blasterfan on January 21, 2007, 10:43:00 PM
in my old side kick i used to tow a 1300 pound quad trailer, hard on the hills for sure, but seemed ok on flat ground, just gotta watch your stopping distances big time lol
Post by: 4njeep on January 22, 2007, 01:53:26 AM
i wouldnt do it. if you really want it, why not borrow a truck or rent one.  that way you wont kill yourself when you cant stop.
Post by: Digger on January 22, 2007, 07:09:24 PM
It was me. I used my silver 90 Tracker to tow home my green 93 Tracker on a tow dolly, probably at least 50 miles through the hills of western PA. Silver's running the 8v and 5 speed and was wearing 31" swampers at the time. I could only smell the clutch when pulling out, while I was running down the road, it was fine. Stopping distance is huge and I pissed off some big rigs on the up-hill parts cause I was moving slower than they were.
That said, the Tracker's recomended towing capacity is rated at 1000 pounds. You probably wont find a trailer designed to carry a car that weighs less than that empty! Your best bet would be to find a trailer big enough for both trackers and use a tow rig big enough to pull it.
The curb weight of a stock Tracker is right around 2500 pounds or so...
(http://pic20.picturetrail.com/VOL72/842221/5455528/88528452.jpg)
Post by: Praise Him on January 22, 2007, 07:55:43 PM
1,500lbs
Wrong....1100lbs, See manual
Post by: droppedtracker on January 22, 2007, 10:09:33 PM
i checked my chilton repair cd and it says to find out the towing compacity muiltply the engines hp by 35. then subtract the weight of passengers and any cargo. the number that is left would be the max. about of weight a tracker can tow.  so if you have the 1.6l 16v motor multiply 98 by 35 which is 3430.then subtract passengers and cargo. say 400lbs for passengers and cargo which equals 3030lbs. keep in mind that weight includes the trailer, so if you have a car dolly thats what 400-500lbs? so 2530lbs is the most a car can weigh.
Post by: derekj on January 22, 2007, 10:55:49 PM
we tow a 500lb sled on a small utility trailer (400lbs?) with the 235 snow tires on it and that is about all i would tow with it. plus the gas mileage sucks huge with the sled on. its not as bad as the sled (6 - 10 mpg) but you sure notice a difference.
derek
Post by: ROSS on January 23, 2007, 03:54:19 PM
it's not the towing it' being able to stop it without killing someone
Post by: 97TRAKIN on January 23, 2007, 05:06:46 PM
1,500lbs
U.S. 1997 and later 4-Door Tracker claims 1,500 in door jam. Same for all 4-Doors (excluding XL-7) even V6.
Post by: beercheck on January 23, 2007, 06:40:07 PM
Stopping's for quitters.
Post by: Digger on January 24, 2007, 04:33:33 PM
1,500lbs
He says right in his original post that it's an 8v, which means it's older than 95-96 ::)
Max HP of an 8v tracker is 85, so multiply 85 by 35 and you get 2975. If you stick with your 400lb estimate for passengers and cargo(which I would take up 3/4 of just by myself ::)) you end up with 2575 pounds, then 400-500 pounds for the dolly and around 2075 is the max the towed car can weigh...
Or you could just look up the factory recomended towing capacity and find out that it's listed as 1000 pounds max total....
Post by: Rhinoman on January 25, 2007, 05:15:05 AM
Mine wasn't that bad even towing a heavy load. It stopped OK but it took more pedal travel and just felt a little disconcerting. A lot of it depends on how well set up the trailers brakes are. I also never had any clutch problems, the 8V pulled amazing well although it was fairly new. Second or third gear was needed for big hills though.
