ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: museboy07 on January 25, 2007, 07:37:29 PM
can i put power steering in my 94 track thats got manual steering...if so what will i need?
yup the stering box is exactly the same exept for the hidro lines.
I just put power steering in my 92 tracker the other day and the gear box is not the same it is larger.The pump and resevoir are easy hookups.Also make sure you get the intermediate shaft from the unit as u will need the shorter shaft becouse of the diffrence in size of the gearbox.Good luck and have fun.
It is a complete bolt on. You need the steering box with pitman arm, the pump with pulley, the steering shaft, the resevior, the lines, and a longer belt.
Anyone seen a write up anywhere?
