ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: MIDZUKI on February 01, 2007, 05:33:58 PM
Title: 7 inch lift and 33's
Post by: MIDZUKI on February 01, 2007, 05:33:58 PM
will i be able to clear 33's with 6.5 to 7 inches of lift in a samurai?
Title: Re: 7 inch lift and 33's
Post by: costa 05 on February 01, 2007, 08:17:13 PM
NO PROBLEM
Post by: Praise Him on February 01, 2007, 08:32:54 PM
I cleared 33's with SPOA and 2' con-fer shackles....
Post by: track_this on February 02, 2007, 03:12:12 AM
2'= 2 FOOT, HOLY JESUS :o i hope you meant 2"(inches) hahaha. ;)
could you imagine 2 foot shackles just picture it a min. made me laugh.
Post by: rahb on February 03, 2007, 06:59:55 AM
what are con-fer shackles?
Post by: Drone637 on February 03, 2007, 10:12:40 AM
Extended shackles.  Probably 1 or 2" longer then stock. :)
I cleared 33's on just a standard SOA with a bit of hammering on the front and cutting the rear fenders out a bit more.   :)
Post by: MIDZUKI on February 03, 2007, 10:26:57 AM
got pics?
Post by: phloop on February 03, 2007, 03:39:13 PM
I have had 32" swampers on my rig for the last ten years. At first I only had a SPOA, with the seam on the inside of the fender well hammered flat. Then I went too a 1" Sky body lift, and then some Con-Fer 1" shackles. The 1 1/2" lift did not make much of a difference in the fit of the tires. I also have some SpiderTrax wheel spacers, I am not sure if that makes a big difference other than the turning radius.
And be sure your bump stops are where they should be. Better for the axle to hit the bump stop than the tire to hit the body.
Post by: phloop on February 03, 2007, 03:42:08 PM
I forgot too add, I have replaced the front bumper along with cutting off about 8" of the round tube on both sides of the frame that the front bumper mounts too.
Post by: Drone637 on February 03, 2007, 11:29:54 PM
(http://www.dttm.net/files/SJ410.jpg)
This was with the stock springs on the front.  :)
Post by: Amilla on February 04, 2007, 10:41:20 AM
Thats looks very beasty, how well is it off the beatin path?
-Amilla
Post by: Drone637 on February 05, 2007, 02:04:41 PM
I have a spool in the rear and had a Detroit Ez-Locker in the front, so it goes pretty much anywhere I point it.  The only problem is with tire size obstacles, sometimes you just don't have tall enough tires to get over.  But that is what the winch is for.  ;D
I found a couple more images.  Here is one from when it was first put together before a trip to Moab.
(http://www.dttm.net/dboard/files/re_dcp_0012.jpg)
And my flex back then.  :)
(http://www.dttm.net/dboard/files/resize%20of%20postpic4.jpg)
And a shot of my flex now.
(http://www.dttm.net/dboard/files/03-26-06_1220.jpg)
(http://www.dttm.net/dboard/files/03-26-06_1223.jpg)
I probably enjoy showing off my SJ too much.  :P
Post by: MIDZUKI on February 06, 2007, 02:31:14 PM
nice, man those look close to rubbing. any problems with that?
Post by: Drone637 on February 06, 2007, 03:01:42 PM
I had to pound the back of the fender a bit to get it to stop rubbing while with the stock springs.  When I switched to the RUF setup we cut the front of the fender.  It is hard to tell from the pictures, so I attached a file to show the difference.
Right now it will just barely rub when I stuff my fender up nice and tight.  When I first put it together I had some clearance, but the springs are broken in and lost a little bit of flex.  Longer shackles or having bump stops that worked (aka lined up with the axel instead of being 2.5" behind it) would fix the problem.
