ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: 3wheelerdude on February 07, 2007, 11:35:04 AM
Title: Fuel Injection issue
Post by: 3wheelerdude on February 07, 2007, 11:35:04 AM
Hello all,
Got a problem with my 96 sidekick. Forst of all it wont start and some relay in the dash is making an awful ticking noise.
I found out that the Fuel Injection fuse under the hood was blown. I replaced it and it blew again. I replaced it again but with a 20amp instead of 15 and the kick started, the relay stopped ticking, but that lasted about 5 seconds and then the fuse blew again.
Any ideas......
I m about to start tearing the electronics of the fuel injection system.
Joe
Title: Re: Fuel Injection issue
Post by: Rhinoman on February 07, 2007, 01:21:46 PM
It could well be a fault in the ECM itself. However before condemning it I would start disconnecting the external circuits, pull off as many plugs as you can find and see if the fault goes away. Then start plugging stuff back in one connector at a time. Known problem areas are the O2 sensor (can go short circuit) and fuel pump wiring (top of tank and behind rear light).
