ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: museboy07 on February 07, 2007, 01:12:46 PM
i just bought some jeep tj coil spacers for my 94 track and i need to know the size to bore the center hole out to....the current hole is 2 1/8" in diamater
2.5" im about 95% sure on that
ok thankyou...but this coil spacer has a lip which seems that it would sit down into the coil to keep it in place...if i bore it out to 2.5 in then it will no longer be there...is that lip absolutely needed?
Check out this thread:
http://www.zukiworld.com/forum/index.php?topic=7930.0
im goin to drill the center to 2.5in so should that be enough? on the one side of the spacer there is a cone shape drill down in bout 1/2" im guessing this is where it will sit on the coil cup?
I did mine today 2.5 is right. My daystar 1-3/4" jeep spacers didn't fit in front I had to bore them out. They did fit fine in back tightly... I need a drill bit to finish the rear shock mounts. I'll be done tomorrow if I can figure out the camber situation.
