ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Chief on February 07, 2007, 06:31:57 PM
see other thread.... 8)
If you hear a "pop," I would suspect a hard short to ground. If you measured the resistance to ground at the circuit side of the fuse, you will probably read less than 1 ohm. I would look for a pinched wire.
Disconnect the coil and see if it still does it. That should tell you if its the coil or the wiring.
