ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: museboy07 on February 09, 2007, 10:59:03 PM
would they fit??
does anyone know?????
well i dont know much about tracker wheels but i will tel u this......
if ur tracter wheels 15" in diameter & if ur tracker wheels are 7" or more wide ull be ok!
I've seen it done but the stock Tracker wheels are too narrow.(5"inch wide)
5" wide, u sure, thats like crazy.... if they were like a 6" u might be able to get away with a 9.5" tire
I put 235/75/15 mud terrains (29") on my stock 96 tracker wheels. Even with a 2" body lift, it rubbed quite a bit on the frame and fender at full lock :-\. Really did not like the look either. The wheels kept the tires inside the fender well and did not give it that wider stance that I was looking for. I bought the 2.5" off set wheels from RR and fixed the problem ;D.
