ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: TOPIK3900 on March 06, 2007, 07:45:42 AM
WHAT KIND OF FAB DO I HAVE DO TO PUT SPOA KIT ON MY 85 SAMURAI IS THERE ANY WELDING ARE CUTTING OF PARTS ON THE AXLES OR ANYTHING LIKE THAT
You have to cut the U-bolt guide off the top of the axle then weld on the spring perchs.
Amilla
IS THERE ANY KITS OUT THERE THAT DONT REQUIRE WELDING??
Im not sure if there are any kits that dont require you to weld on your spring perch.
I think someone sells a non weld on spring perch, but im not 100% about that. I cant remember where i saw it, but they were a bolt on style. Not sure how strong it is.
If it were me i would go for the weld on ones.
How come you dont want to weld anything?
I think most of the vendors selling spoa kits sell them with EZ weld spring perchs. Its a no brain thing, you set them on, line them up and weld them.
If you dont have a welder you can take it to tons of differnt shops and they would do it for pretty cheap.
Amilla
Amilla
WITH ALIGNING THEM UP IS THERE ANY SPECAIL WAY OR ANGLE THEY HAVE TO BE SET AT OR DO THEY JUST HAVE TO BE LEVEL WITH THE BODY, GROUND OR SOMETHING LIKE THAT.
calmini sells a fully bolt on kit. its sold 3 differrent ways. if you like the way it
rides and sits you can weld it if you want. they'll stand behid there kit if you have a
problem. take a look at it and aee if thats wha you want. this s the only bolt-on kit
that I know of.
