ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Element on March 07, 2007, 04:42:16 PM
Title: Coolant leak out of the back of my 1.6
Post by: Element on March 07, 2007, 04:42:16 PM
I am leaking coolant from where the tranny and engine come together... A freind said it is most likely the freeze plugs... head gasket was replaced not too long ago. Anybody know anything about doing this project?
Title: Re: Coolant leak out of the back of my 1.6
Post by: daddyizzle on March 07, 2007, 06:18:18 PM
Any possibility it's leaking out of a heater hose and seeping back to where it appears like some kind of another leak?
-Adam
Post by: 96Kicker on March 07, 2007, 08:51:42 PM
A heater hose would be alot easier than pulling a engine to replace the freeze plugs.
Lets hope that is all it is jerry,that will save us alot of time before moab.
Post by: ROSS on March 07, 2007, 08:54:16 PM
jerry check your email
Post by: Element on March 07, 2007, 09:05:01 PM
I will take a better look... The engine looked dry on top... I hope it is something easier!!!
Post by: ROSS on March 07, 2007, 09:08:51 PM
get up on top with a brite light and realy double check . even have someone else look
Post by: Element on March 07, 2007, 09:10:48 PM
Is my 65 lumen 6p Surefire bright enough???
Post by: ROSS on March 07, 2007, 09:12:35 PM
don't blind yourself.  you gotta drive at moab in three weeks
Post by: Element on March 07, 2007, 09:15:18 PM
LOL! My wife hates that Toomey gave me a surefire as a gift....It will never get old to me showing someone how bright my little flashlight is...LOL!  How does this sound? I can replace the heater hose and see if I still leak... iff so... pull the engine on friday! By the way... Where is the heater hose...lol
Post by: ROSS on March 07, 2007, 09:21:35 PM
look at the firewall . you can see both and follow them
one goes to the tube that comes out of the waterpump  the other goes to firewall
heater control valve then to the intake. theres also a couple small ones
Post by: Jeremiah on March 08, 2007, 12:31:43 PM
I thought for SURE my head gasket went on my sami, but it ended up being a coolant hose that came to the back of my carborator. $1 fix. Look carefully, and make sure you know where that leak is comming from.
Post by: ROSS on March 08, 2007, 06:10:15 PM
Jerry
how bad does it leak?? find a little dutchman to put his finger in the hole
Post by: Element on March 08, 2007, 06:22:09 PM
LOL... would that be safe? Not so much for the dutchman, but my vehicle... he could get all wrapped up in my driveline or something... The leak is bad enough that it bothers me... it has a slow constant drip....
Post by: ROSS on March 08, 2007, 06:33:31 PM
did you check everyhere??  all hoses , connections, clamps
