ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: museboy07 on March 10, 2007, 04:49:06 PM
hi, i gotta 94 track and i recently adjusted my valves. they needed just a lil adjusting. One i was all finished i drove and it was fine...now theres a ticking noise at the top of my engine...what the hell is it????
Maybe you left your screw driver under the valve cover?
You might have incorrectly adjusted a valve, causing it to tick.
are you sure its not your fuel injector?
How can you determin if its an injector? mine only ticks in the mid RPM range nothing at low rpm and it goes away at high rpm
is there anyways to get new injectors to get rid of it ?
or is it just something that happens with these vehicles?
Don' know much about zooks yet but typically a noise like that is a valve or lifter.
