ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: TrakJD on March 16, 2007, 05:45:51 AM
Title: 1.6 8v not starting... ECM FIXED.
Post by: TrakJD on March 16, 2007, 05:45:51 AM
I have 1990 Geo Tracker 2 DR tintop
I got the ECM fixed, new battery... replaced the distributor... Nothing's starting.
Everything worked before I pulled the ecm out to fix the sputtering and idling.  Then it eventually went dead.
COuld it be TPS? Throttle position Sensor?
Any inputs would be greatly appericated.... THanks.
Title: Re: 1.6 8v not starting... ECM FIXED.
Post by: Rhinoman on March 16, 2007, 05:51:57 AM
Are you sure that you have the distributor correctly aligned.
Post by: Yoak on March 16, 2007, 09:46:25 AM
Start With Basics First...
Are You Getting Spark?
Are you Getting Fuel/Is your Fuel Pump Starting?
