ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Grizzqc on March 20, 2007, 05:48:05 PM
Title: front 4x4 wont work
Post by: Grizzqc on March 20, 2007, 05:48:05 PM
Ok it shifts fine on shifter 2h truck moves 4hi truck moves only rear wheels neutral truck does not move 4 low truck moves only rear wheels.Front drive shaft is turning but front drives are not even with hubs locked what should I check first before ripping it all aprt?Any info would be great as I am a newbie :-[ :-[ :-[ simplest things first please :-[ :-[
Title: Re: front 4x4 wont work
Post by: balance on March 20, 2007, 05:49:52 PM
i would check the shift linkage. its a start
Post by: Element on March 20, 2007, 05:52:35 PM
What vehicle are you running? Have ya had it for awhile? When did it start?
Post by: GmManDan on March 20, 2007, 05:54:17 PM
I would just pull the hub off and make sure it has grease in it make sure its not rusted up. It happened to me when I bought my sammy. A quick cheap fix it is only like 6 bolts.
Post by: ROSS on March 20, 2007, 05:57:28 PM
its not the linkage if the front driveline is spinning.  check the hubs.  if you pull the hubs off you can see the end of the axles . see if there turning. if yes fix hubs. no fix spider gears or lockers
Post by: Grizzqc on March 20, 2007, 06:31:52 PM
just got truck it has been sitting for over a year.It is a 91 tracker two door if I new how to put a picture I would lol
http://new.photos.yahoo.com/grizzqc/album/576460762394437738
Post by: GmManDan on March 21, 2007, 02:36:47 AM
If it were me I would say hubs needed to be lubed or I would at least start from their.
Post by: stock93tracker on March 21, 2007, 10:36:50 AM
yup, the hubs may need redone.. One of the ones I got was junked up and wouldnt engage, Im just gonna rebuild it.
Post by: ozziel on March 21, 2007, 04:25:27 PM
Yup. I would also guess hubs.
If you need a set send me a message, I'm sure I have some spares around here somewhere.
Montreal area.
Post by: Grizzqc on March 22, 2007, 06:01:26 AM
thanks ozz
