ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: JDMCRX on December 21, 2004, 03:29:34 PM
WOndering what u guys got in ur 8 vlave im looking for a cam and wondering which to get more highway power.
Custom Grind, Engle Cams
Santa Monica Ca.
Slight more lift and duration, I don't remember
the specs, but I asked for a smog compliant cam
anyone got a calmini or an Isky?
stu
Check out reynoldsmachine.com they have heads withall the trick work. I'm looking at there stage III for $659.39. ;D ;D ;D
Kevin
or a hawk cam? I would like to know how they perform as well? I would guess cam and header should make a noticable increase in power for the 8V?
Stock ;D
stu
I just bought ( but have not received yet ) a rebuilt head with a Calmini cam. Once it's installed I'll let you know what I think.
It's going on/in the engine after I receive the Weber 32/36 DGAV I bought from a guy in the US, he sent it to MidWest Performance ( Sarge ) who is going to set it up for bolting it on my Sammi with one of his flowed intakes. I also bought headers, so all the changes at once will make  difference I hope  ;)
[edit]Well, that plan changed a bit since I bought the Camden SuperCharger 2days ago ;), but I will still use that head with the Calmini cam, shave the head just a little, I just have to take in all the advise I can find on the Internet and all the advice from people "in the know" to make my final plan [/edit]
Stock ;D
Same here :)
did the isky cam in the 1.6 8V and noticed nothing.
did the isky in a 1.6 w/1.3 head and pony carb, very torquey between 2200-3500 rpm, lots of pull
driven a 1.3 with the isky and dt header and noticed a big improvement torque in a wider rpm range
my conclusion, not worth it for the 1.6 8V. try this guy he's in BC so it'll be a bit cheaper for ya
http://www.coltcams.com/index.html
Yeah im thinking of getting the HAWK cam and shave the head .20thou.
And hope to see some gains. Cause motor swap is not in my option.
  Kevin
Thats like $160 more than a Summo II and aside from a new rocker shaft, It's about the same thing.
Anyone what u guys think about the HAWK cam?
Stock ;D
yea me too >:( >:( >:(
stu
im thinking of taking the head off shave it .20th and changing the valve stem seals and putting the cam and some slight port work. Hawk cam
for that kind of money just get a used 16 valve and be done with it!
Im in canada and i can not find anything also 16v head wiring ,header, so forth
a link to another similar topic (canadian forum)
http://www.zookpower.ca/forums/showthread.php?t=1416&highlight=colt+cams
Sent colt cams a email ive heard good reviews on there cams. If they can have a cam ready soon ill put it in and let u guys know how it goes cause no one on this board has done a cam in there 8vlaves.
I'm running the high torque cam from Colt Cams and have noticed a improvement in my bottom end power. No diff in hwy power tho that I noticed.
I've been running a Hawk cam since 1997. It's performed well. Can't say how much of an improvement it (the cam) actually itself contributed.......I installed a header and a Jacobs ignition at the same time. I have been very impressed with the overall performance............But the 8V has finally been beaten for 15 years and withstood some very hard and unrelenting abuse, about to install a 16V.
doing anything with the old aftermarket stuff(yes this means i'm calling dibs ;D :P)
stu
So what cam is better for highway power
