ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: zukigroundpounder on April 01, 2007, 06:11:26 AM
hello
i got me a sidekick and was wondering if any of you guys have any ideals on how to lift it without spending a a lot of $$$$$. i need to lift it about 3 inches so it does not belly out in ruts.
thanks
ps post some pics of your lifted rig if you have any.
I lifted my 1997 4dr using 1.5" coil spacers and a 3" Masterkit1 body lift. I sell the coil spacers on e-bay look under seller name: hoepkers. The spacers are 49.99 and up., cheap lift compared to others.
Just do a 3" body lift. Calmini has them for around $150. That will move you belly up enough.
Not sure what you are talking about, a body lift won't raise the belly at all...
The frame will be sitting exactly where it was before the lift, except that you will be able to put a larger tire on, and that will raise you a little.. no more than an inch or two.
You need to do a coil spring lift, or at least a coil spring spacer.
Coil spacers are the cheapest, and work fine. You will need longer shocks for the rear, if you don't want to limit your axle travel, and longer struts, strut extentions, or a strut mount flip for the front, for the same reasons.
A 2-4" spacer or coil lift (or combo of both) plus a little trimming will allow 31" tires WITHOUT a body lift.
Can you do a 4" coil spacer?
hello
and thanks for the replys what do you mean by the strut mount flip? tell me a little more about it. also what kind of shocks are you guys running on the back of your rigs? and yes quaddawg the frame is what i'm trying to get up out the ruts thing sits to low and just doing a body lift wont get it. just about done the cross menber in on the thing this evening got to get it lifted up some.
thanks rick.
I flipped the strut mounts, used 1-3/4" spacers and '91 Ford Crown Victoria Shocks, $20 Monroes. Works great!
Good thread for strut mount flip
http://www.zukiworld.com/forum/index.php?topic=13687.0
hey thanks alot that was just what i was looking for.
Maybe this'll help.
http://www.granitepath.com/~kd7hcg/sidekick/pictures/budgetbodylift/index.html
Maybe this'll help.
[url]http://www.granitepath.com/~kd7hcg/sidekick/pictures/budgetbodylift/index.html[/url]
BLEH on body lifts... :P
I with testify that Heather's Budget 5" lift is one of the best suspension mods you can do if you're on a budget.
I disagree that body lifts are bad. If done correctly, they can accomplish a few things A) get the body (rocker panels) further off the ground, and B) Allows the fitment of a larger tire without having to hack the fenders.
While some vehicles that have measureable amounts of "Cancer" may actually benefit from this, cutting a perfectly clean body is unnecessary for 31's. Besides, a body lift is reversible, while hacking is not.
Zukisidekick
a 2" coil spacer lift, strut mount flip, and crown vic shocks with a little trimming should do great with some 31's. and i have to agree with quaddawg on the body lifts. they dont give you any more ground clearance, which is exactly what zukigroundpounder needs more of, and why this topic was started in the first place. besides, if you rip off the rocker panels, you cant drag them over rocks anymore. >:D
hello
well i done the strut mount flip yesturday and also changed the rear shocks. i also trimed the rubber bump stops on all for corners and removed the stablizer bar in thee front of the thing.now all i need is some coil spring spacers you guys are talking about and i'll be good to go. anyone have a good ideal as to where to buy these? i dont have a flebay acount stop using it after getting burnt on there a few times. or i'll buy a set off one of you guys iif you have any for sale just let me know.
thanks again for all your help on this i love this fourm lots of great people and lots of info and help.
rick.
are there any other front and rear coil springs that can be use on the sidekick other than the oems that will work good that any of you all know about or have tryed? just wondering about that also what about a set off a 4 door kick would they be any better than a 2 door kick springs?
thanks rick.
I used Digger spacers with the strut mount flip and put 3'' front cherokee shocks in the rear (had some lying around)I ended up putting a limiting strap on so the springs don't fall out.
I have used Digger Spacers, they are top quality.
I am using BDS springs, struts and shocks... overpriced, but they work fine.
OME makes great springs and struts
and once again. DOUBLE BLEH on body lifts.. ;D
thanks rick.
GV springs are supposed to work well. Give around 2" of lift.
I'll sell you a set of 4 new 1.5" new coil spacers for $75 including shipping or 4 new 2" spacers for $90 including shipping. Look at them on ebay, seller:hoepkers. You can pay me with money order and I'll ship right away. Read some of my feedback, you won't be disappointed. E-mail me direct at hoepkers|removethispart|@charter.net to talk more about it.
you have mail and pm.
thanks rick.
I think ones off of the grand vitras give you lift too.
Jeep Grand Cherokee springs give about 3" of lift I believe.
hello
thanks i did not know you could use the jeep springs. have you used them or anyone you know of use them? let me know i know where i can pick up some of these cheap.
thanks rick.
??? I wish I would have seen this before I bought my 1 1/2 inch strut spacers for $60. Does it matter what year Crown Vic for the rear shocks? Do I still need to do a body lift to fit 31's? I bought the spacers from hoepkers on Ebay.
Dont want to spend alot, buy just the boondox 2.5 lift coils, or 3inch lift coils, and there strut spacers.... Rest is up to you.....
I bought the 4 door 3 inch lift springs, strut spacers... tossed them in my 2 door, sitting on 31x10.5's
(http://www.zuknation.net/tracker/FB3.jpg)
What shocks did you buy for the rear?
hello
thanks rick.
I am using jeep grand cherokee front springs in the rear of my tracker. They give approx. 6" of lift. Cut the little end off the top, they fit right in. Just have to make new pocket for the bottom. Nothing 3 1/2 " tubing and flat plate can't fix.
hello
on the shocks if i remenber right i think they told me 91 vic shocks work real good. as for the jeep coils i pick up a set of those yesturday and going to go today and get some gv coils from a friend of mine and see if they will work. as for the coil spacers i have a friend that just made the coil spring prech on the rear and front 3" taller than the factory one on it they work great i'm planning on doing mine that way and then redoing the rear shock mounts to on the back.
thanks rick.
hello
thanks rick.
So what springs did you use for the front then?
i have a 92 tracker 2dr. here is what i did. i have 2in heep spacers all the way around and a 3in home made body lift. i am now running 34x10.5 swamper ltb only a little trimming on the front fenders (i already trimmed bumper b4) its a 5spd 1.6 512 gears and moves them bid tires fine around town. i havent taken it off road but im sure tires would be hitting on something. also i just made 3in strut extenders today to put on my front end doesnt bounce at all even with new struts( i think they are on a bind /fully extended or something) just my 2cents worth.
hello
the 3in strut extenders you made do you have Any pics of thema? i'd like to do thAt to mine in the front.
thanks rick
hello
thanks rick.
Do you have pics? What did you use in the front?
trackenator we need to see a picture of your rig on 34's! I have the same lift with 31's and would like to go to 34's also or 33's
yep me to i have 31-9.50-15 And would like to run 32's or 33's would be nice but dont need the rubbing and cutting off the fenders.
rick.
