ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: dbr on April 01, 2007, 07:50:26 AM
I have a lot of slop in the shift pattern of the trans. :(
What is the fix for this? ???
Check this out!!!
http://www.zukiworld.com/month_090102/feature_hawkshifterpinfix.htm
;D
Thank You!!!
You may just need the bolt and bushing. Sometimes they may be bad enough that you may need to replace the shifting tower... Take a look at the bushing and be very careful taking it apart. If the shifter pin is broken, do your best to extraxt it so it doesn't fall deep into the Abyss!!! You can find those bushings at many places... However, it is such a hot item... they can usually be on back order.... Worth the wait reguardless...
