ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Ranchergirl on April 08, 2007, 05:27:29 PM
Title: Calmini Shackle Reverse
Post by: Ranchergirl on April 08, 2007, 05:27:29 PM
Could someone please tell me if the calmini 2" shackle reverse is hard to install.  Do they have pretty good instructions?  Thanks for all you help.
Title: Re: Calmini Shackle Reverse
Post by: calabrias1962 on April 08, 2007, 06:21:05 PM
They are prety easy the only problem i had was one of the spring bolts was siezed in the bushing and broke but i eventualy got it out. Spray all bolts with PB blaster a few days before you do the install so everything comes apart easyer. :)
Post by: Bigzook on April 08, 2007, 07:32:26 PM
Buddy of mine just installed one. said it was super easy and took like 4 hours total. I warned him about the spring bushing bolt problem but he said his came right off.
Pic, it's the white one.
(http://i32.photobucket.com/albums/d35/bigzook/03-23-07_1443.jpg)
(http://i32.photobucket.com/albums/d35/bigzook/03-23-07_1445.jpg)
Post by: speedball1981 on April 08, 2007, 09:59:55 PM
I havn't Installed one,  but I just scrapped a samurai with one on it and removing it only took me like 2 hr's total,  and it seemed pretty basic,  a lot less complicated than a spring over,  wich only took me like 6hrs start to finish.   :)
Post by: rivercitysammy on April 09, 2007, 06:43:14 PM
the reverse shackle system is the easiest kit to install ever. You just need some penetrating oil and your all set. I actually just installed the 5" lift kit on mine from calmini on the weekend. and all my kit is, is a reverse shackle kit with heavy duty 3" leaf springs. the instructions are really helpful and easy.
Post by: ROSS on April 09, 2007, 07:35:40 PM
if you can tighten a bolt with a wrench you can install the kit.  super easy to do.
Post by: Element on April 09, 2007, 07:57:12 PM
Well, it sounds like that kit is out of the question for me and other zukiworld users...
>:D
 ;D
Post by: ROSS on April 09, 2007, 07:58:51 PM
NO I SAID YOU HAD A SCREW LOOSE
