ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: museboy07 on April 10, 2007, 06:47:57 PM
Title: Will 30x9.5-15 fit on my stock track wheels?
Post by: museboy07 on April 10, 2007, 06:47:57 PM
will they? cause i dont have the money for wheels now but i just put a 3in lift on and i need bigger tires
Title: Re: Will 30x9.5-15 fit on my stock track wheels?
Post by: Armour on April 10, 2007, 07:22:39 PM
I would think there should be no problem. You can run a 12.50 on an 8 inch rim so why not 9.5 on a 7. I think that is what stock is.
Post by: Trackin92 on April 10, 2007, 07:47:19 PM
im not sure but i am running 235's. How close are those to the size of 30x9.5??
Post by: kirknd4spd on April 10, 2007, 10:52:38 PM
yep, it will fit. there isnt much difference between a 235/75r15 and a 30x9.5
Post by: museboy07 on April 11, 2007, 04:14:57 AM
30x9.5 are just a bit bigger then 235s right?
Post by: Rhinoman on April 11, 2007, 04:48:12 AM
A 30 x 9.5" tyre should be on a 6.5" to 8.5" rim. It will probably fit on a stock rim ( 5 1/2") but I wouldn't advise it for road use. A 235 shouldn't be fitted on a stock rim either ( 6" to 7" rim needed). To be absolutely certain you should check with the tyre manufacturer as fittings can vary a little.
Post by: bzzr2 on April 11, 2007, 10:46:00 AM
i run 31x9.5's on my stock rims which are either 6 or 6.5 on the model i have, they work fine.  they'll just rub the frame a little when turning real sharp.
Post by: Trackin92 on April 11, 2007, 11:21:16 AM
yea my 235's are on 7" wide rims and I think they look pretty good on my Tracker on stock height. They stick out about 2" but it looks good like that. I plan on gettin 32's maybe just maybe 33's if i feel like spending more money lol
Post by: john1974 on April 11, 2007, 11:26:34 AM
hell im running 31x10.5's on 15x7's ;)
Post by: Trackin92 on April 11, 2007, 11:28:16 AM
whatever works lol. When i eventually get my lift i want to get new rims preferrably 15x8's and I found some wheels i really liked by Dick Cepek I believe was the name of the company.
Post by: crikeymike on April 13, 2007, 11:30:06 AM
A co-worker has 30x9.5 BFG AT's on stock wheels and he has no problem.  The nice thing is that he can air down pretty far without risking losing a bead since the tire is on there tight.  The width is good inside the fenders too, if you're trying to keep it close to stock.
