ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: blakester1123 on April 13, 2007, 05:44:18 PM
35 inch tires on stock samurai axles with the heavy duty shafts? whould it break or would i be fine if i had the gear to turn them?
I think the double tuff and newfeild berfs. (correct me on the name if thats wrong)
are supposed to be able to hold up to that size tire.
Amilla
checked them out on trail toughs site it says to use rear samurai side gears, does this mean you could run a rear spool in the front?
Sounds like you can run that rear spool up front.
yep
