ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: brace on December 11, 2004, 05:25:53 AM
Is it possible to put a 90 t-case on a 87 Sammy?
Yes  the flanges will be larger and you will have to redrill the holes for your drive shaft flange into the case flange by rotating 90 deg,.
Do I have to redrill every flange coming off the t-case flange?
yup
Now is a prime time to put them YOTA axles under it!You can use the YOTA drive shafts modified to length(bolt pattern should match)stock 4:11 gear, bigger axles.You can even put disk brakes on the rear easily!Whats not to like,but wait a minute that leads to bigger rubber,lockers,beadlocks,etc,etc.It never ends but its fun,eats up all your spare change,increases your colorful vocabulary,and on some occasions when that tool slips draws blood ! ;D M.Z.
I tend to stay pure with my zuk which means no toying around. Any way I just need to get thru the winter. Modding isn't an option. When I get back from Korea I will get a Kick or Tracker and go nuts. A whole year w/o zuki, bummer.
