ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: kingzoo on May 06, 2007, 01:24:43 PM
Title: brake problem please help!!!
Post by: kingzoo on May 06, 2007, 01:24:43 PM
  I just put front rotors and pads on my 1991 4 door sidekick.I forgot to remove brake fluid from the master cylinder before using clamp to push piston back into caliper.Some fluid leaked out of the top of the master cylinder,and the safety switch beside shifter clicks   when I apply brakes in park.Will bleeding the front brakes cure this issue up?If not,what should I do?
  Any help will be appreciated.
