ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: jerryp58 on December 11, 2004, 09:21:59 AM
Title: Confused about what's behind the timing belt cover
Post by: jerryp58 on December 11, 2004, 09:21:59 AM
OK, please take a look at the very center of this picture...
(http://home.att.net/~jerryp58/tracker/fixtracker3.jpg)
Is that gaping hole below the water pump and between the oil pump and the block supposed to be there  ???
The water pump doesn't cover it up.  I would think I'd be dumping oil all over that area.  The timing belt is not supposed to get oil on it, is it?
And if oil is getting in there, I'm thinking that the oil may be spraying out of the timing belt cover at two hole mine has in it from the pulleys.  Here's the pic of that...
(http://home.att.net/~jerryp58/tracker/fixtracker1.jpg)
Help!  What's the deal?  Is that hole/gap really supposed to be there?
I thought my front crank seal was leaking, but now I'm not so sure.
Title: Re: Confused about what's behind the timing belt c
Post by: Mikerpm4x4 on December 11, 2004, 01:54:20 PM
No your front crank seal is probabally leaking. Its common. While your in there put a cam seal in too. I think they are the same part# too.The holes in the cover are cause the seal has been leaking for a while and warped the cover. I usually keep the cover off and save it as a tool for timing.
Mike
Post by: wildgoody on December 11, 2004, 02:28:44 PM
That's not a hole, it's a hollow spot
and it's full of oil, is your engine a 16
Valve ? looks like a wide timing gear
on the crank.
That's what we need, and aluminum
timing belt cover, so it won't warp and
get holes worn in it from the belts and
pullies rubbing on it.
Post by: explosivo on December 11, 2004, 04:41:39 PM
Now you've got one more thing to manufacture for the Zuki'n masses! Hurry, I want one!
Post by: jerryp58 on December 11, 2004, 11:15:34 PM
Mike
Yea, I guess now that I'm in this deep I'll change both front seals.  Hopefully I won't have any problems getting the crank bolt & gear off  ::)
Mike
You can definitely see the warpage in mine.  But, YIKES, aren't you worried about getting liquid & debris in your oil through that hole/gap?
Post by: jerryp58 on December 11, 2004, 11:20:56 PM
on the crank.
What the heck is the "hollow spot" for?  Why would they give oil the opportunity to enter the timing belt/gear area?
Edit -- Ahhhh, I just looked over your post again.  It's just a hollow spot.  So, it isn't some kind of passage to an oil reservoir.  I was thinking it was an opening to my oil supply, not just a spot that has collected oil that's not even supposed to be there in the first place.  Now I understand  ;D
Well, I know it's a 8v head, and as far as I know it's an 8v block, but I don't know what or where the production numbers are that identify the block.
Yea, plastic might save weight, but it's not always the best solution.
Post by: Mikerpm4x4 on December 12, 2004, 12:52:09 AM
The motor is sealed. That gap does not go into the oil. Ive only had a problem with not having a cover once, but I was up to the headlights on thick mud in my old sami. The mud packed between the belt and the crank gear and popped it. On the upside all I had to do was remove the aly belt and slide a new timming belt in there.
Mike
;D
Post by: Speedracer7c on December 12, 2004, 12:55:07 AM
Mike
;D
What is the advantage of not running a timing belt cover? Are there any, and does the belt wear prematurely?
Post by: wildgoody on December 12, 2004, 04:07:31 AM
The only problem is something getting in
there and popping the belt off.
I have a friend with a sand rail 2.3L Turbo
Ford T-bird motor, a few times sand got
packed into the belt and it popped it off,
other than that no problems
Post by: jerryp58 on December 12, 2004, 07:40:00 AM
Mike
;D
I finally understand that the motor is sealed.  The idea that there was an opening to the oil supply behind the timing belt cover was freakin' me out.
I'll probably try to patch mine and put it back on.
Post by: jerryp58 on December 12, 2004, 07:40:56 AM
I'll probably try to patch my cover and put it back on.
Post by: Speedracer7c on December 12, 2004, 09:51:08 AM
DUCT TAPE!  ;D
Post by: mrfuelish on December 12, 2004, 03:00:10 PM
Duct tape and j.b. weld  ;D I just time my 16 valve through the bell housing  8)
Post by: jerryp58 on December 12, 2004, 09:26:06 PM
DUCT TAPE!  ;D
Don't tempt me  :)
I'll have to look at how much clearance there is on the inside.  Although, if I JB Plastic Weld a "patch" in there and it breaks loose  :o
Post by: wildgoody on December 13, 2004, 02:36:33 AM
Clean the cover really well, like with
brake cleaner, duct tape the inside
for a backing, now flip it over and
squeeze some black silicone into the
worn holes, let it cure and pull the tape
off of the inside, holes fixed, and silicone
should stick really well if it was clean.
Then again, the holes don't really matter,
so just slap it back together and go wheeling
Post by: Mike71 on December 13, 2004, 03:39:55 AM
why does mine have no wear marks on it but his has gaping holes? doesnt that mean something isnt aligned right? is that SUPOSED to happen  ???
Post by: jerryp58 on December 13, 2004, 07:24:48 AM
What?  You cover doesn't have the breather holes :o  You need those breather holes.
If you want, I'll trade covers with you, and then I can just cut breather holes in your cover with my special "breather hole template"   ;)
Someone said that when the cover gets oil on it, it warps.  I don't know if that was the cause or not, but mine was definitely exposed to lots of oil and it is definitely warped.  That's why the W.P. pulley and the belt wore holes in it.
Post by: explosivo on December 13, 2004, 11:38:46 AM
Wait, you mean there's someone out there that doesn't have warped/gouged out timing belt covers? Huh? :o
Post by: Mike71 on December 13, 2004, 12:16:57 PM
yah no rust oil leaks or holes anywhere
Post by: Speedracer7c on December 13, 2004, 12:18:20 PM
Yeah, I got to replace mine after the tensioner broke and blew the side of it apart!  :o
Post by: jerryp58 on December 13, 2004, 12:38:04 PM
Where did you get your replacement and how much $$$ (if you don't mind my asking)?
Post by: mesjr2004 on December 13, 2004, 01:16:10 PM
i wouldnt recomend running without a timing cover.  my son had a strong running 16v w no cover.somthing got between belt and pully and jumpped timing at about 5000rpm, bent all of the valves. i didnt run a cover,now i do
