ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Fasta76 on May 23, 2007, 09:54:39 PM
Title: 91 sidekick power stearing on a samurai?
Post by: Fasta76 on May 23, 2007, 09:54:39 PM
Can i take the pump and power stearing box off a 91 sidekick and put it on a 86 samurai? im thinking of doing the 1.6 swap while im at it also!! If i want to run my carb, is there anything else i need besides the bellhouse adapter and electric fuel pump? I just use my distrib off my 1.3 right?
Title: Re: 91 sidekick power stearing on a samurai?
Post by: mlovetripp0 on May 23, 2007, 10:54:06 PM
you will need the motor mounts ,to adjust for size of motor.
is there much difference between a 91 steering box and pump ,then a 96?
i just got done putting power steering on my 87 sammi.and it has a 16v 1.6 in it
and the stock location for the pump would not fit next to the steering box.we had to make a bracket using the old pump bracket and bolt it more towards the head of the motor.the steering box from a track/kick is much larger then the sammi's.but sooo worth it
Post by: Fasta76 on May 24, 2007, 05:59:35 AM
im not sure if there is much size difference??
