ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: BigRedZuki on May 30, 2007, 05:28:32 PM
Hi i'm new to this forum and to the wide world of zuks specifically sidekicks beacause i recently picked up a red 96 4 door sidekick for free :) :) :) and i am looking for a lift kit and a body lift. were i will drive it the most is on highway but i want to take it offroading. i have looked at everything and cant decide which one or parts of multiple kits.
i need a new motor :( ??? :( ??? >:(
budget?
Coil spacers are a cheap way to lift it. The best lifts are full spring and arm kits but for 3" you're looking at a grand!!! I make coil spacers if you are interested. they work good, no one has had any problems with them. I've sold about 60 sets on ebay. Look under seller name: hoepkers. A body lift is also a cheap way to get bigger tires on but it does not help the suspension at all. Masterkit makes a pretty good one as is Calmini's. I also make 2" coil spacers if you want. Welcome to the forum, the guys on here truly know everything about Zuk's.
jeffs coil spacers are top notch...love em
i was thinking to get masterkit1's (also cause i live in canada cheap shipping) 3 inch body lift and there 2 inch lift because it comes with strut spacers as well and then when i need new shocks springs i would get a new set of old man emu struts and springs kit. 6.5/7 inch total lift :) :) :)
ya your spacers are nice and cheap they look good too do you make strut spacers
yea because I need some of those spacers i dont want to do the whole flip the strut mount thing. How much will those be running a pair?
Sorry guys I do not make strut spacers right now. I am going to, I need to change my struts and when I do I'll measure my spacers and make some.
if i get a 3 inch suspension lift will i have to get an axle spacer and front diff drop brackets. and if i get a 3 inch bodylift will the shifters be long enough. i need to know everything that there is on lifts before i buy. is the calmini lift good for street driving beacause it will be my daly wheels
Go with the spacers - they actually provide you with REAL lift - the body lift does not get you anymore frame-to-ground clearance. You'll need strut spacers (cheap) or do the front strut flip (free), and cheap ($20) crown vic shocks in the rear.
what is a front strut flip ive never heard of it
http://www.zukiworld.com/forum/index.php?topic=13687.0
The Calmini 3" kit is designed for the weight of a winch and winch bumper on the front and for wheels with a greater offset. The 2" kit is more suited to a daily driver without the extra gear. The Calmini suspension kits come with all the parts. Spacers are a cheap way to get lift but a properly engineered suspension kit will give you better articulation as well.
The bodylift will need extended gearlevers.
thanx
also what lift is good for saving my cv's and alignment.
is ome 2.5 inch lift good
I'd stick to 2" or under if you're not fitting diff drop brackets. The OME lift is 1.4", the extra inch comes from additional spacers. Any lift will affect the alignment.
