ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: museboy07 on June 03, 2007, 07:48:04 PM
Title: Need to level out...
Post by: museboy07 on June 03, 2007, 07:48:04 PM
I just installed a set of Jeffs 2in coil spacers and now the front sits a little higher.  Bout an inch i think.  If I were to swap in a set of 4door coils in the back (mines a 2door) you think that would level me out?  They supposedly give about an inch of lift.  If so then ill fab up a rear a arm spacer and some longer shocks (currently running crown vics)  Any input?
Title: Re: Need to level out...
Post by: biker on June 03, 2007, 08:27:26 PM
You're right on the money, 4 door coils will level you out nice. Flex it out before you buy more shocks but the A-arm spacer is a good idea
Post by: museboy07 on June 03, 2007, 08:35:51 PM
thanks biker just wanted to clear that up.  But what do you mean flex it out before more shocks?
Post by: biker on June 03, 2007, 08:42:54 PM
flex the susp to maximum to see if your springs start to come loose. Probably will flex better with the spacer in there
Post by: museboy07 on June 03, 2007, 08:50:14 PM
ya im thinkin it will.  Should i use a 3 in spacer for it since i would have a 3in sus. lift?
Post by: biker on June 03, 2007, 08:52:53 PM
I would match it to the lift for best effects, Just remember to make it really strong as it takes a lot of abuse
