ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: bus_driver on June 04, 2007, 12:23:58 AM
what is the camber from stock on my 92 kick .... i did the spacer and now i am about too grind the holes b4 the lift it looked like 0 degrees or really close if someone could let me know that would be great. and if i do it at 0 and then the toe at 0 would that be ok i use to run 0 toe on one of my cars and it gave me under steer and then massive oversteer but that was a track racer and dd it also was runing 1.25 negative on the camber. so i guess my Q is 0 camber and toe is this ok.
thank you
That's pretty much how I set my Tracker up after I did the lift. 0 and 0. I think it ended up with about 1/16 th " toe in after it settled. Drives good.
STEERING
Toe In 2-6mm (0.08-0.24in)
Camber Angle 0 degs 30 mins
Caster Angle 1 deg 30 mins
geat thank you very much that is will be easy to achieve at home appreciate the info.
