ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: SunrunnerGT on July 19, 2007, 08:41:52 pm
I was thinking about putting some platinum plugs into my 8valve. What do you guys think? What are the best pluges for these motors? I have been using ACdelco plugs and they been doing just fine sofar. Thanx for your thoughts
NGK
ngk v power - dont bother with the platinum - i had a set in my truck and didn't make a difference in the way it ran.
derek
If you want to get fancy get some bosch plus fours and index them and cut off the ones you don't need x3, i.e. put them in and mark the intake side of the plug, pull one out save the one nearest the mark and cut the others out. (you will see what i'm talking about once you buy them.)
platnum will put a lil pep in your step dont go cheep do the whole wires plugs cap rotor your rigs worth it
I thought that NGK V plugs were platinum.
never like bosch much seen many of them come apart :( I run the v-power they work good for me
Ryan
Wishful thinking. NGK V plugs are the way to go.
