ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: RifleRide on August 18, 2007, 03:01:59 PM
I just purchased a Sammy and the guy told me the tranfer case was stuck in 2 WD. It was such a deal, I felt there couldn't be much wrong. Any ideas on what I need to do first to try to get it into 4 WD ?
Try a search but I think sami's have the transfer case sheet problem, cheap and easy fix.
http://www.zukiworld.com/forum/index.php?topic=13910.0
Try a search for shifter sheet at Ack's FAQ (link in signature, below). You'll find several links to pages (with pictures!) describing how to install a new shifter sheet in the transfer case - a somewhat difficult task if you are totally unfamiliar with mechanical stuff. Heck, it can be difficult even if you are semi-smart!
The total parts cost of the fix is less than 20 bucks (including shipping).
You'll also find some informative links with a search for transfer case.
Hope this helps!
My t-case was stuck in neutral. Just replaced the shifter sheet (purchased at lowrangeoffroad.com $14.) and now it works fine. Easy
