ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Digger on November 13, 2004, 12:30:56 PM
Title: Hi Lift mounts?
Post by: Digger on November 13, 2004, 12:30:56 PM
Ok everyone, where do you all mount your hi lift jacks?(those that have them, of course). I know I have seen a couple mounted on the front bumper rebar(the steel part under the cover), and I've even seen one mounted across the top of the Targa section of a Tracker. Mine is sitting behind the backseat with the end up on the side, strapped to the seat belt tower, but I would like to do something better with it.
If I cut 6" off of it to make it a 42" jack, it could ride flat behind the back seat on the cargo floor, but I would prefer not to have to do that.
So come on and post pics of your hi lift mounts, I want to try to get some ideas... ;D
Title: Re: Hi Lift mounts?
Post by: 92Sidekick4x4 on November 13, 2004, 01:33:47 PM
kregs idea is kinda cool, mounted on the rear bumper
Post by: TN_Tracker on November 13, 2004, 01:33:52 PM
Here's a pic of mine bolted on the front:
(http://img.photobucket.com/albums/v133/RockSolid4X4/Tracker/hilift6.jpg)
I never liked the idea of having something that big and heavy laying loose inside the cab. In a rollover or accident it could take your head off. :P
Post by: Digger on November 13, 2004, 01:44:25 PM
I know what you mean, I don't like it riding inside free either, that's why I strapped it to the seat belt tower, but I would prefer to have it mounted outside, somewhere out of the muck. I can't really mount mine to the front bumper due to the shape of my bumper plus all the stuff in the way, ie: winch, lights, D-rings, etc... I'm in the process of creating my rear bumper, but don't really like the idea of having it mounted across the rear bumper due to the amount of mud it would collect there.
I had it strapped to the spare tire vertically with a couple of mountain bike toe straps, but they didn't hold up to off road abuse. After I get my lift and tires on, as well as the matching-size spare, I was thinking about making a mount on the spare holder somehow...
Post by: TN_Tracker on November 13, 2004, 01:49:42 PM
...I was thinking about making a mount on the spare holder somehow...
I thought about the same thing but since I have my cargo rack back there it was out of the question. Post some pics when you get it done.
Post by: safarikick on November 13, 2004, 03:26:40 PM
http://www.rhinoman.org/mods/jack_mod01.html
that from the uk
Post by: chrisvitarasport94 on November 13, 2004, 07:50:36 PM
I was keen to mount mine on a bracket plate onto the spare wheel, which could double up as a base plate in soft ground - lots of such mounts for land rovers - WWW.safarigard.com - but I became concerned about the extra weight and leverage on the door.
I have a roof rack, so I bought the Jack-Rack accessory, and mounted these onto the latteral roof bars with 2 pairs of exhaust U clamps.
It's up out of the way, and instantly accessable, but it's exposed to the weather.
As a base plate I got an offcut of a waffle board - be enterprenurial - buy a pair of boards cheap & cut 'em up and sell to all your mates!
Post by: 1bigtracker on November 14, 2004, 03:31:10 AM
i have a 60in and have the same prob.  i need a 60in because my tracker is fairly tall but i have no place to put it.  i might but end up bolting it to the outside of the truck somewhere if it will fit.
stu
Post by: 92Sidekick4x4 on November 14, 2004, 03:40:21 AM
if i get a jack all, im having a bumper made custom and id probly have the guy make it so i can mount it on the back bumper and take it on and off as i go out wheeling.
Post by: red_baron on November 14, 2004, 08:22:21 AM
i just bolted mine to the roof bars on my lwb vitara.
bit of a step up to get it though. :D
Post by: chrisvitarasport94 on November 14, 2004, 09:08:42 AM
 - not so hard to reach when you're stuck in 2 feet of mud !
Post by: SnoFalls on November 14, 2004, 10:17:14 AM
And how exactly do you use a hi-lift in 2 feet of mud? :)
Post by: HotRod on November 14, 2004, 11:12:19 AM
My Hi-lift is mounted on the Calmini Rear bumper with an extrra part they charge extra for but don't advertise. ???
(http://memimage.cardomain.net/member_images/4/web/496000-496999/496556_66_full.jpg)
I've only used it once so far and I used the RockSliders for a lift point to change a guys flat.
The poor guy was trying to used his stock jack on a lifted Tracker by placing the jack on a rock.
Post by: chrisvitarasport94 on November 14, 2004, 05:15:21 PM
use in mud with a base plate and hi-lift mate to lift a wheel to fit a waffle board underneath
Post by: Rhinoman on November 14, 2004, 11:05:52 PM
Eventually the base stops going down and the truck starts coming up  ;D
Post by: jagular7 on November 15, 2004, 01:20:10 PM
A hi-lift is a good tool for what it is. It's mostly a lifter and puller. Once you get to a certain bumper height, and have not enough droop, the hi-lift is a prime user. If the droop is too excessive, without chaining up the axle to limit droop, the hi-lift becomes unstable and potentially dangerous in lifting a vehicle. Hi-lifts are good for lifting something off the ground. Good for pushing something off a rock or tree. Good for using as a winch with rigid hardware (no straps).
For a lifted vehicle with good axle clearance, I've always found a good tall bottle jack very capable of changing a tire, lifting the bumper off a rock (actually had myself pinned on an off-camber climb in all rocks and stuck my bumper on some flat rock which rolled. The rear tires weren't touching at all).
So at some point, hi-lift, at other times, a real good bottle jack. The stock bottles should work fine, but really show the limitations rather quickly. Good bottle jacks will run near $30 with a case, folding sticks (which can be used to clear broken shafts out of axle housings), and a good wide platform.
I have all but the lowest size hi-lift. I don't trust my 60" too much with my 6500# Bronco. But the bottle jack, not a problem as the suspension gets loaded as the tire is lifted off the ground.
To mount the hi-lift, do note that it is used in the elements. So using it in mud, then have to pack it inside......Can be secured very simply in parts if really necessary. Can be secured with bolts and wing nuts. Lube with lithium grease (helps keep the real dirt out). Use several times in driveway as the holes and locking shafts won't really line up. Always keep your hands tight on the handle when there is a load on it. Stand to the side of the handle. Do not place your fingers from the other hand on the jack. Once the hi-lift starts popping up and down due to the weight, it will hurt if the handle smacks you. I've seen broken fingers due to being crushed on the shaft. I've seen broken jaws when the handle slaps the face. It can and does damage. Be careful.
Post by: Digger on November 16, 2004, 01:58:50 PM
Yeah, but where do you mount one on a Tracker? ;)
Post by: jagular7 on November 16, 2004, 03:31:13 PM
Since you are capable of welding something together, I'd first find out what size is really necessary for lifting your rig to change a tire. Take consideration of the droop and any future lift developments. (You can always get another hi-lift when needed.)
I'd look at getting a swing out tire carrier, add the hi-lift to the vertical mount and secure the bottom to/near the swing point. This placement requires a note of the wheel/tire depth from the backside to mount the spare.
I may sound like an old goof, but when you are not experienced or knowledgeable on the dangers, I just hate to see people get hurt.
Post by: 92Sidekick4x4 on November 16, 2004, 04:19:27 PM
not sayign this as a joke but u can never be to safe
Post by: wildgoody on November 21, 2004, 06:26:03 PM
If you ever get wacked in the jaw
with that handle you wish you didn't
Post by: Rhinoman on November 21, 2004, 07:49:02 PM
Main problem with a Track/Kick isn't finding somewhere to mount the hi-lift but finding somewhere to use it. I lift on the front winch bumper and the rear towbar. The rear towbar is easier to get underneath without the spare wheel mounted on the door. One day I will make some rocksliders with built in jacking points too.
Post by: wildgoody on November 22, 2004, 03:33:10 AM
Ya, me too, build the sliders to make
changing tires easier, this one at a time
takes too long, I like to do one side at a
time, but the floor jack on the frame won't
lift the tires off the ground  ;D  and blocks
are too dangerous   ;)
Post by: eskyman73 on November 22, 2004, 05:00:23 PM
A shovel & winch is easier than a high lift jack anyday to get on solid ground then change your flat... :)
Post by: wildgoody on November 22, 2004, 06:13:00 PM
I'm talking about changing tires
in the driveway, from streets to
Swampers, one corner at a time
takes too long  ;)
Post by: Digger on November 23, 2004, 01:38:06 PM
There are times when just about any recovery item is useful, from shovels and hand saws to winches and hi lifts. I beleive in being prepared and have just about everything in my Tracker; come-along, winch, hilift, shovel, bow saw, gloves, various length straps, clevis's, D-rings, etc...
I think for now my hi lift will continue to live in the back with one end up on the side, strapped to the seatbelt tower. At least it stays nice and clean this way...
