ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Eden1 on September 02, 2007, 08:42:47 PM
Title: help me decide???
Post by: Eden1 on September 02, 2007, 08:42:47 PM
can anyone tell me if the 16 valve motor produces more power?and how much more?i have a 8 valve right now and was also wondering how big a job it is to swap these?like the mounts ,electrical and tranny?thanks for the help guys
Title: Re: help me decide???
Post by: museboy07 on September 03, 2007, 05:33:43 AM
8 valve specs..
1.6 litre 4 cylinder SOHC   8 valve (G16B)  80HP/94 Lbs.
1,590 cc, 75.0 mm bore x 90.0 mm stroke, 8.9 compression ratio
16 valve specs..
1.6 litre 4 cylinder SOHC 16 valve (G16B)  95 HP |removethispart|@ 5600 RPM , 98 Lbs |removethispart|@ 4000 RPM
1,590 cc, 75.0 mm bore x 90.0 mm stroke, 9.5 compression ratio
Yes there will definitely be a power difference if you do the swap.  To my knowledge, the 16 valve has the same exact block as the the 8 valve.  Only the head and the electricals  are different.  So the mounts should be the same.  So you will need the engine with with all the accessories, wiring harness and the ecm.  Keep us posted if you do the swap.
