ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: bandit86 on September 09, 2007, 08:58:08 PM
friend is using a tracker frame for a kit car, needs to lower it. I heard of firebird front struts, anyone know anything else? wont need a lot od suspension travel, the strut tower will be cut and lowered, just need a short strut
Don't have a clue on how to lower one
But pics of the kit car project would be interesting.
If you don't need so much travel can't you just shorten the springs and add limiting straps to stop the front struts over extending (and letting the springs fall out!).
the strut towers hit the hood, need shorter struts so the strut tower can be lowered for clearance
How far does it need to be cut?
4 inches shorter would be nice, take what we can get at this point
If you want to do the work you could just eliminate the struts all together. Do a setup similar to Mike Haggens front end.
what did he do??
http://www.zukiworld.com/month_050106/feature_hagen-newfrontend.htm
Redesigned the front end and eliminated the struts. Then you could put some mini-truck shocks on or something.
