ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: museboy07 on September 13, 2007, 12:37:02 PM
Automatic tracker with 5.12 gears, high performance 2in exhaust, high flow cold air intake and 32s....would it turn the tires ok or not?
It should turn them pretty well. A few people are running Trackers with 32 and stock gearing.
Of course it will turn them. The 5:125's should help enough.
For what it's worth, the power loss isn't that bad. My old automatic(with the 4:62's) Tracker had 31's on it before it's death, and it was okay, a little sluggish at times, but it is a 4x4, so...
just buy your stuff and get er' done :)
Right on brother...I think ill give it a shot. It can't be no worse then my old tracker that was pushin 80lbs of compression from each cylinder. I'd park on a slight incline and put it in gear and it would roll away with the engine turning...haha
My Dad's rig has that exact same setup and it works very good.
Kevin
PS at 70 mph he is running 3k rpm
So he has an auto with 5.12s and 32s?
