ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: nevadasmith on November 14, 2004, 03:50:37 AM
Hey Im going to order a lift monday or tuesday. and wile im sure this quest has been asked befor but,,,,, for my 91 tracker which is better? i want 2 1/2-3" of suspention lift. Also is this enough to clear 30x11.5's or do i need a body lift to?
depends, if you want your tracker to ride like a caddy then OME. but if you want flex but a harsh ride then calmini.
stu
stu
Or you can mix and match parts with the Calmini lift and have a decent riding, good clearance, good flexxing lift ;)
For twice the cost!
humm, make me think about how OME struts would work with a calmini 2in. :D
stu
I've run the OME on both the swb and lwb. In my opinion it rides and handles better than the stock setup. Good at speed and and an easy install. I'd suggest using this with coil spacers, camber bolts, longer rear shocks than the OME and a spacer for the rear diff. I now have the Calmini 3" with the OME struts and ARB winch bar and winch on my lwb. Firm is the furthest from the description I would use. It has a very soft ride and flexs much more. I don't like the way it uses the springs as bumpstops but that's fixable. I find the nose dives more on hard braking causing the rear to unweight and lock the rear brakes more easily. It will give you more flex offroad, is built strong and you can mod it further if you want.
i have only heard things baout the 2 different companies, don tknow anyhting abotu them really cuz i dont have their products, you will be able to fit 30"x9.5"s on there with no lift at all, well at least i did
hey thanks for all the in put I think i'm going to go with the ome lift. if for no other reason than idont have to drop the frount diff and in nevada the smoother the ride the better!!!
??? what is a rear diff spacer? Is it like a drive shaft spacer or something else?
Yeah, driveshaft spacer, I have it, works like a charm.
I was just at rock roads web sight and know I'm a little confused does there kit use the ome rear shocks or dosetech? are the dostech longer or better? are they $80 more or what? do I need a drive shaft spacer on 2.5" lift?
The RR kit comes with the DT shocks. They have more travel than stock. You don't need a spacer with the 2.5" lift. If you want a soft ride then get the lighter springs...I have the heavier springs in mine and the ride is very firm...but I like it that way.
thanks for all the help guys!!!! ;D
stu
On my rig the Calmini lift rode AWESOME. The thing that I know I will regret the most about changing out running gear is losing the ride on rough trails :'(
Brian
Nope, have a look here  http://www.cabrito.suzukioffroad.com.br/Upper%20wishbone.htm
now I see the light, keeps the ball joint on the third link from binding is there a web site or place to order it in english?
Here it is in English(sort of)
I don't know of anyone who sells it but this page tells you how to make it.
http://translate.google.com/translate?sourceid=navclient-menuext&hl=en&u=http%3A%2F%2Fwww%2Ecabrito%2Esuzukioffroad%2Ecom%2Ebr%2FUpper%2520wishbone%2Ehtm
;D thank you!!
That diff spacer is exactly what I was thinkin of the other day so thanx to you guys/gals now I can get to fix my diff bang problem. ;D ;D
All the best keep on zukin along
