ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: PhnxCaller on October 02, 2007, 07:59:18 PM
Does anyone know where I can find a Brake Proprotional Valve for a 87 sammy? Just looked under the truck today and a steady stream of fluid was pouring out of the valve. Its located about half way down the passenger side of the frame and is a little alum. deal. I can't seem to find one anywhere ??? This year has two rear brake lines (info only). Any help or fixes would be great!!!!!
spider trax sells one , Also look|removethispart|@ http://www.lowrangeoffroad.com/sambrakes.htm (http://www.lowrangeoffroad.com/sambrakes.htm)
The two valves listed will not work as the one he is looking for a stock valve.
I have one. Make me an offer. I'll go pull it now. The carcass goes to the wrecking yard tomorrow. It says aisin on it and has three lines out of it and one bleeder. I'll p.m you.
-Adam
Yeah mine is the stock valve, found one through Rod's samurai salvage, but there has to be another place to find it! Maybe I could modify a single line version off a 88 or newer or from a sidekick/tracker!?!
mine's from an 88.5 for what it's worth.
-Adam
