ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: nerd on October 11, 2007, 04:14:19 AM
Title: 16 valve sammy swap.
Post by: nerd on October 11, 2007, 04:14:19 AM
hi i just joined this forum and recently bought a 1988 tin top samurai with a bad engine...ive found a 4 door tracker in a junk yard and i want the engine out of it...what all should i take from the 4 door to complete the swap?  besides the engine haha
Title: Re: 16 valve sammy swap.
Post by: SnoFalls on October 11, 2007, 07:41:05 AM
wiring harness,
ECM (if you wanna run EFI)
Power Steering pump and box (if it has it)
Post by: nerd on October 11, 2007, 08:11:27 AM
do i need the power steering stuff? im not planning on making the samurai have power steering
Post by: Rhinoman on October 11, 2007, 10:46:35 AM
You don't need the power steering stuff but its nice to have  ;D. Grab the speedo as well if you're fitting EFI because you'll need the vehicle Speed Sensor which is screwed on the back of the speedo head. Make sure you get the ECU on its bracket with all the relays attached.
Post by: nerd on October 11, 2007, 12:01:48 PM
awesome....thanks for all the input keep it comming
