ZUKIWORLD Model Specific Suzuki Forum => Suzuki Grand Vitara, Vitara, Chevy Tracker (Gen. 2 Platform) 1999-2005 => Topic started by: 90Stomper on October 24, 2007, 05:47:45 PM
Title: more 03+ v6 locker info
Post by: 90Stomper on October 24, 2007, 05:47:45 PM
ok, i just ordered a Calmini 2.5 lift.  AFTER, i ordered i asked about how to get a NON ARB locker into the rear.  they were very nice and helpful.
the reason they say that no one sells a locker for the 03+ trackVits is that some had the R&P and carrier parts made in the US and some were made in Japan.  they say that there is no way to tell what each car has in it, what ever they got, they put in.  output shaft spine # and dia are all the same.  but there seems to be a difference on the ring gear and carrier dimentions.  according to Calmini, their limited slip dif
http://www.puresuzuki.com/limited_slip2.htm (http://www.puresuzuki.com/limited_slip2.htm)
will fit in some.  when/if i get their lift and install it i am going to take measurements and call them back.  they will be able to tell me if the LSD will fit or not.  their LSD is pricey but it doesnt need air, air lines, compressor, or anything once installed.
i dont know if this effects non-US vits but it might.  i will post in this link with more info when i learn more.
Title: Re: more 03+ v6 locker info
Post by: bzzr2 on October 24, 2007, 07:40:25 PM
i read a post on one of the forums - not sure which one, a while ago and a guy tried this and it didn't fit.  hopefully you'll have better luck!
Post by: 90Stomper on October 25, 2007, 05:56:20 PM
thanks, i hope so too.  you dont have a link to the other guys info or link?  maybe i have a different one than he did.... ???
Post by: bzzr2 on October 26, 2007, 08:24:39 AM
i think it was on zookpower.ca under the IFS section, you can view there like here without being a member.  he was told it would/might fit, tried it with no luck.  i would put the lsd in if i could also.
Post by: IanL on October 26, 2007, 11:41:45 AM
I'm having difficulty understanding this approval for LSDs.  As I understand it,  they allow a small amount of slip (i.e. limited) before they let go and you lose drive.  So this is absolutely no help if you have one wheel off the ground.
They have their uses, for race tracks, etc, where a wheel can lose a bit of traction due to rubber on the road, or a sharp bend, but I don't see them as useful for an off-roader, or have I got it wrong?
Post by: beercheck on October 26, 2007, 12:52:22 PM
Yeah, you've got it backwards.  They limit the amount of slippage between wheels on the same axle.  With an open differential, once one wheel slips (begins to spin), it gets ALL the power and the other wheel gets ZERO.  An LSD, if working properly, will ensure that even when one wheel is spinning freely, the other wheel will at least get a little power.  Might be only about 5-10% (depends on all sorts of stuff), but any traction is better than no traction.
Post by: 90Stomper on October 26, 2007, 07:18:32 PM
thanks for the info BZ!  i will see what i can find.
i too think that a lsd is second choice, but yes, it is better than nothing.  i had a lockrite in my 90 and loved it.  yes it had drawbacks, but it was solid, and always instantly locked when a tire slipped.  100% power to both wheels 8)  but at this point i will take what i can get :'(
Post by: IanL on October 27, 2007, 01:11:28 AM
According to the Calmini site, it is not available for manual V6s.
