ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Pettit on November 20, 2007, 06:22:05 PM
Title: Turns over but won't start...fuel pump?
Post by: Pettit on November 20, 2007, 06:22:05 PM
Hello everyone, as you can see I am quite new and I have a pretty important question.  Today, of all days, I went out to start my '88 Sammi and while I was warming it up i heard an almost popping noise from the front end.  It immediately turned off and will not start now.  I checked all the fuses hoping it would be that easy but none of them were blown.  I was thinking it was something with the fuel pump because it sounded like it was turning over fine.  When I sprayed some starter fluid in it didn't start either so now I don't know even know if i'm getting a spark.  All the plug wires are on well so I wanted to see if anyone had some insight before I take it to a shop here in Fort Collins tomorrow.
thanks,
Chris
Title: Re: Turns over but won't start...fuel pump?
Post by: Digger on November 20, 2007, 06:31:00 PM
Well if it's the stock engine, it should have a mechanical fuel pump, so as long as the hoses are connected and it's not leaking, it should be alright. The fact that you say it wont run on ether either means to me that you might have a bad ignition coil. My guess is no spark. Can you smell fuel at all around the carb?
Post by: Pettit on November 20, 2007, 06:41:18 PM
i should have known it was a mechanical fuel pump...sorry brand new.
Would the ignition coil going out cause a "pop" noise?
There wasn't an overly strong fuel odor around the carb that I noticed.  What would that indicate?  Too much fuel pressure to spark?
thanks!!
Post by: wheresmyhat on November 20, 2007, 07:19:03 PM
Pop the distributor cap off and crank the engine. If the rotor is not turning the the timing belt broke. Thats what it sounds like anyways.
Or just take the top and side nuts off of the timing cover and pull it back a little bit. You will be able to see if the timing belt is still on the pulley or not.
Post by: Pettit on November 20, 2007, 07:30:16 PM
good call, I'll run out and try it.
I just read this other thread about ignition coils:
http://www.zukiworld.com/forum/index.php?topic=15932.0 (http://www.zukiworld.com/forum/index.php?topic=15932.0)
I ran a new ground for the coil and that didn't change anything.
I did, however, smell gasoline around the carb if that means anything.
thanks for the help guys...off to check the timing chain
Post by: Pettit on November 20, 2007, 07:46:04 PM
rotor is not turning!!   >:(
sounds like a broken timing belt then...guess i'll go take a peek at it
Post by: ZUKTOY on November 20, 2007, 07:48:31 PM
No spark issue. Reason you smelled fuel cuz it wasn't burnt. Timing belt could be broke.
Post by: Pettit on November 20, 2007, 08:12:54 PM
Thanks fellas, just popped the timing cover a bit and peeked in and the belt was right there on the sprocket with about 1/4" of the sprocket showing towars the rear of the vehicle...but the rotor in the distributer still isn't turning ...
any thoughts?
Post by: Digger on November 20, 2007, 09:52:22 PM
Broken rotor, broken distributor shaft, broken timing belt that's still on the pulley... I asked about the smell of fuel to establish that fuel was getting to the carb, which it sounds like it is.
Post by: Rhinoman on November 21, 2007, 04:51:16 AM
The fuel pump is driven off the cam so if there is fuel to the carb then the cam must be turning. That leaves the drive to the distributor. A short while back a guy in the UK had a problem with the drive gear on the cam moving, its only pressed in place. Time to pull the dizzy and investigate.
Post by: Pettit on November 24, 2007, 09:46:33 AM
turns out there weren't any teeth left on the timing belt so that's why I could still see it when I just popped the top off of it.
thanks for everything guys
Post by: sidekicksrock on November 24, 2007, 09:56:47 AM
Well that would do it.
Post by: beercheck on November 25, 2007, 08:34:42 PM
Pretty much the last thing I'd have thought of.
Post by: Pettit on November 25, 2007, 09:01:02 PM
yeah it caught me just because the belt looked fine at a glance
