ZUKIWORLD Model Specific Suzuki Forum => Suzuki Grand Vitara, Vitara, Chevy Tracker (Gen. 2 Platform) 1999-2005 => Topic started by: rivetc78 on January 09, 2008, 12:36:51 AM
Title: Want a high output alternator - HELP!!!
Post by: rivetc78 on January 09, 2008, 12:36:51 AM
Hello everyone,
Does anyone know if it's possible to convert to a GM style alternator on the 2002 2.0 litre 4 cylinder Vitara?  I want a 200amp alternator but no one seems to make one for my model.
Thanks,
Chad
Title: Re: Want a high output alternator - HELP!!!
Post by: JDMCRX on January 09, 2008, 08:15:31 PM
Sure can be done custom mounts :)
Post by: 90Stomper on January 09, 2008, 08:32:53 PM
i did this with my 90.  put in a GM 12si after changing the pulley, bought the bottom bracket and fabbed the top adjuster arm.  but, its only 94 amp, compared to the old stock 45.  i had the amp rebuild and was told that extra windings could be added for more amps, but they said it was a sort of bad idea and would shorten the life of the alt.  i really think it would fit in a new version Vit, dont know the amp on your stock one...  i have heard of people putting in more than one alt.....  good luck.
oh, and look here for some info too.  maybe call this guy and see if he has any input.  bought from him and talked to him, very nice guy.
http://www.madelectrical.com/electricaltech/delcoremy.shtml (http://www.madelectrical.com/electricaltech/delcoremy.shtml)
Post by: Davyboy on January 09, 2008, 10:37:01 PM
Try these guys:
Ace Alternator (authorized PennTex repair station): (This is where Yankee-Tim got a 185 amp alternator for under $300 shipped!)
Attn: Greg
P.O. 9758
7185 Mohawk Terrace
Yucca Valley, CA 92284
Ph: 877-365-5489 (Toll Free)
Fax: 760-228-9632
I'm planning on getting a bigger alt sometime, too!  Let me know what you find out!
Post by: blacknight on January 10, 2008, 06:05:25 AM
Try these guys:
Attn: Greg
P.O. 9758
7185 Mohawk Terrace
Fax: 760-228-9632
Only issue that I know Tim has with this alt. is the pulley is no the type.  So if you do contact them find out if you can get the pulley matched to the GV.
Geogre
Post by: Davyboy on January 10, 2008, 11:19:10 AM
Has he had any issues because the pulley isn't an exact match?  I don't know a lot about it, but it seems like that might be a potential problem.  Does it cause the belt to slip/come off?
Post by: nprecon on January 10, 2008, 05:39:02 PM
Any down sides to installing a more powerful alternator?  Like do you have to make any other electrical mods to the engine system to carry the additional output from these more powerful alternators... or are the factory wiring and fuzes not affected by this type upgrade?
norm
Post by: 90Stomper on January 10, 2008, 08:00:57 PM
Try these guys:
thats really good info
i dont know about their stuff but when i had my GM one rebuild i had them take the stock pulley off, then i put on a stock one i had and shimmed it, worked great.  think i might have had to ream the center hole a bit...
Post by: rivetc78 on January 10, 2008, 11:35:12 PM
I guess no one makes an all in one conversion kit eh?  (Pardon the eh, I'm Canadian eh?)
Which type of GM alternator is best suited for this conversion?
Post by: Yankee-Tim on January 13, 2008, 07:02:38 AM
The ACE alt required me to splice into the harness, as the connectors aren't the same.  I haven't swapped over pulleys yet, as it needs the GV pulley.  It came with a 6 goove pulley and a smaller diameter.  I've shredded 3 or 4 Suzuki belts, and thats not cheap.
But hey, I got a 185 amp alt! ;D
