ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: RJkick on January 09, 2008, 01:59:07 PM
Title: '92 4 door rear passenger window issue
Post by: RJkick on January 09, 2008, 01:59:07 PM
Well, the window went down and up really slow yesterday and then stopped doing either.  I removed the door panel and some of the rain proofing plastic to see what happened.  The cable had 2 loops sticking out of the regulator, took an hour but I managed to pull those out.
It looks like the cable may have busted since the end of it is now stuck in the top plastic wheel where I assume it used to go around, pulley I suppose.  Does the end mount to something on the window or can I JB weld it to where it broke off or is it the best option to just purchse another regulator\cable assembly?
I looked at a haynes manual but can't tell where the cable mounts to
Any inexpensive replacement suggestions or schematics of where the cables mount?
