ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Speedracer7c on November 01, 2004, 07:54:29 AM
When i swapped diffs out of my car, the one i put in didn't have the rwal sensor. Is there anyway to trick it into thinkin its working so the little light will go out in my dash board?
How bout just taking the bulb out?
put the sensor back in? ;D ;D
stu
That worked for me ;)
It wont pass inspection without the e-brake light working.....
What i did was disconnect the anti lock controller under the drivers side dash.Light went out and e-brake lamp worked normally again
could you go into that a little deeper? what does the Anti lock contoller look like?
stu
stu
It is approx. 3"X4" black box to the left of the steering column,IIRC. It will say Kelsey-Hayes on it. Just disconnect connector, and all is well.
Nice that worked. THanks
Hey, you're wqelcome. i found that easier than pulling the gauge cluster out and taking that apart. I like the K.I.S.S method a lot. ;D
KISS is the best method ever. lol THanks man!
